-   HardwareCanucks F@H Team (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/)
-   -   not getting bigadv WU's? (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/48365-not-getting-bigadv-wus.html)
mikellini November 14, 2011 09:20 PM
So I'm not really sure what's up here, I've folded much more than the 10 required WU's, everything is set up properly and I'm running with -smp -bigadv, but I get either around 5000 or 13000 points for my WU's, not getting any big guys. I read somewhere that there's a shortage, but not one over the past 6 days? advmethods is no, everything should be good to go...
4DoorGTZ November 14, 2011 09:53 PM
Depends on your setup, but there are changes in the future..... Bigadv will require more threads and have tighter deadlines, OC'd single sockets wont be capable.
Link: Folding@home
edit: Link changed to original article - SJ
boggtrotter59 November 14, 2011 10:02 PM
Do you have the "Big" setting configured in the client?
mikellini November 14, 2011 10:37 PM
Yes, WU's are set to big. I have 12 threads @ 4.2 GHz so... any other ideas?
mikellini November 14, 2011 10:40 PM
ah, I see that soon we'll need 16 threads? bummer... I could try upgrading to v7 and see if that helps
boggtrotter59 November 14, 2011 11:23 PM
Hyperthreading turned on in the bios?
mikellini November 14, 2011 11:33 PM
yep, and all 12 threads are being utilized :dots:
krazyups November 15, 2011 05:25 AM
I haven't gotten a bigadv unit in a few days, there might be a shortage.
MARSTG November 15, 2011 06:55 AM
is a bit confusing : this change is for the big beta? or simply regular bigadv units?, mm, seems like the regular bigadv. Bummer, right when I was upgrading to 12 cores. But that also means that all the donors with high powered single socket systems are in the same whole : all i7s and even the Bulldozer, leaving indeed only really powerful machines to do those jobs. I guess too many people trying to cut corners under Linux with those Thubans@4GHz and i5 2500k, because I have seen Zodac as being part of the DAB. And while creating a workaround for that would not be an issue it would be interesting to see what would be the minimum required for a 16 core machine to finish in time. I guess on the upside, we can still hope that Linux will net more PPD than Windows.
Keywork November 15, 2011 08:30 AM
Same here. It's been several days at this point and my PPD output is showing it lol.
