Old October 12, 2011, 04:32 PM
BrainEater's Avatar
Interesting....
I removed the -advmethods flag .....
The first unit I got was a 12000 point unit......seemed to produce 3900 ppd-ish.
It just got an 1803 point unit (small im assuming)...running 3000 ppd.
I'm going to set the size flag to small and see what happens.
Supermicro X11DPi-NT:2x Xeon Gold 6144's:Lots more other stuff.Dual 4k monitor video .
Old October 28, 2011, 04:09 AM
MARSTG's Avatar
any updates?
Old November 9, 2011, 01:59 PM
BrainEater's Avatar
Ok......
I have an update.
Now , I'm not going to break down workunits ,or settings other than the WU size.
Setting the workunit size made no difference.
Still 2-2.5 Kppd at best....still seems low.
Dont' really care tho , I'll probably give Mr. q9450 it's well deserved retirement from folding.
Old November 9, 2011, 02:23 PM
geokilla's Avatar
Yea SMP PPD has dropped a lot. Used to get around 6k. Now I'm getting half. Might stop folding altogether.
Old November 9, 2011, 04:48 PM
vbironchef's Avatar
+1 I feel the same way.
Old November 10, 2011, 08:25 AM
MARSTG's Avatar
I tried Ubuntu over Win 7 and I got 9.6k ppd on a unit that win 7 usually was giving around 7k. Unit took 25 hours to complete on a Phenom II @3.2GHz. So you guys might want to set it up as a dedicated Linux folder if you have a quad around and are unsatisfied with folding results under windows.
Old November 10, 2011, 03:03 PM
BrainEater's Avatar
I've retired the q9450.....It's done thousands of WU's , it doesn't owe me anything.
It's being relegated to server duty right away anyways , SB-e comes out monday , I'll let my new chip worry about the SMP.
Old November 10, 2011, 04:35 PM
geokilla's Avatar
Aren't Linux WU different from Windows WU?
  #19 (permalink)
Old November 13, 2011, 06:41 AM
MARSTG's Avatar
Are they? For SMP? I wasn't aware. Anyway, for windows SMP client I deactivated -advmethods flag and I get units that take less time to process.
  #20 (permalink)
Old November 26, 2011, 03:08 PM
BrainEater's Avatar
OK.
I've un-retired the q9450......it's now a dedicated folder.....I've put it back onto Windows XP......
Running regular SMP , "big units" (as instructed by the install guide) , back to 4-5 kppd....I would not have thought the OS difference would be that much , but it is.
Now that cooling isnt an issue (it's in the garage), I'll be OC'ing that sucker too , we'll see where it ends up.
Looking for a review between 5870 crossfire vs 5970 variants Mark Video Cards 4 April 27, 2010 07:27 AM
XFX 5870 Variants on Fan and cooler FreeKnight Video Cards 8 April 23, 2010 06:58 PM
