Old October 1, 2011, 02:48 PM
Default Laggy CPU after starting folding
I have just restarted the GPU folding on my gf's rig and I must say the whole computer gets quite laggy, its an i3 530, with a GT 240 ddr5 and 4gb RAM.
Based on my experience with my own rig (in sig), this is not normal, I could game while folding, here I have a hard time using FF. On average the CPU usage is at around 20% on 2 threads, peaking at 100% whenever I start to do a little something. The other 2 threads basicly peak at 20% max. The priority is set to low.
Old October 1, 2011, 02:53 PM
stoanee's Avatar
Try stopping gpu folding while using computer, it may not be able to handle using cpu+gpu+general use.
heatware
Old October 1, 2011, 02:56 PM
I am only GPU folding, there is no folding done on the CPU.
Old October 1, 2011, 02:59 PM
stoanee's Avatar
Hmmm...you could try a different priority manager to see if that helps.
heatware
Old October 1, 2011, 03:14 PM
I think it is the video card lagging. I have a GTS 250 and a 9800GTX and they lag too, only the 460GTX is not lagging while folding.
Old October 1, 2011, 03:35 PM
lowfat's Avatar
That is the thing w/ GPU folding. Quite often it makes the GUI choppy/laggy. If you are using the system tray client you can try lowering the 'CPU Usage Percent' in the advanced panel. I generally keep mine around the 85% mark.
Old October 1, 2011, 04:24 PM
supaflyx3's Avatar
As lowfat said, unless you have a higher end card it'll be laggy unless you turn down the priority. My GTS250 and 460 lagged pretty bad, my 560ti doesn't lag quite as bit.
Old October 1, 2011, 05:39 PM
stoanee's Avatar
heatware
Old October 1, 2011, 06:10 PM
Shadowmeph's Avatar
I was having a lag issue ( not doing gpu folding though) and it seemed to stop once I stopped using the FAH client control and just used FAH6 I still getting some lag once in a while but it is more like a stutter for maybe 1 second.
Old October 6, 2011, 07:38 AM
after rearranging the cards, changing the slots, I made the GTS 250 the display card and although I am folding on it and on the CPU using all 4 cores, there is no lagging. so I guess is something else. i also removed the ATI drivers, I had mixed cards, ATI and nVidia, and maybe that was the issue.
Starting ALL over Malam Troubleshooting 19 November 6, 2010 07:30 PM
PC choppy/laggy issues. stephenc44 Troubleshooting 4 April 14, 2010 06:37 PM
Starting Έρεβος Safearus Case Mods, Worklog & Gallery 12 September 17, 2009 02:01 PM
F@H + XP = sluggish/laggy web surfing? Silvgearx HardwareCanucks F@H Team 9 July 14, 2009 06:29 PM
laggy computer...I think its hardware related Computergeek Troubleshooting 36 March 29, 2008 06:51 AM
