  #41 (permalink)
Old October 4, 2011, 04:29 PM
3.0charlie's Avatar
I have no idea, since the case I'm using (Norco RPC-270) is EEB-compliant. Size is indeed same, but hole pattern may be different. You may have to drill and tap new holes to match the board.
  #42 (permalink)
Old October 4, 2011, 06:39 PM
3.0 do you know who are these guys at INVENTEC and how come they have a brand new 2P board for socket F at only 85$ at serversupply.com? T2112604 INVENTEC MOTHERBOARD SERVER BOARDS SOCKET- F
  #43 (permalink)
Old October 4, 2011, 06:42 PM
3.0charlie's Avatar
Never heard about neither - Inventec, nor serversupply.com.... and the socket F is the last generation vs. the C32 / G34 sockets.
  #44 (permalink)
Old October 6, 2011, 07:49 AM
so given the fact that it will have 8 FPUs instead of just 4 as the Core i7, you think AMD FX will beat Core i7 2600k when it comes to folding performance?
  #45 (permalink)
Old October 6, 2011, 10:26 AM
Dead Things's Avatar
Clock for clock, I would bet the farm on it. Cores > threads for symmetric processes 10 times out of 10. The only question is, how well will it overclock?
Join the PPD revolution!
Proud to be Folding @ Home
deadthings @ Team 37412
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
  #46 (permalink)
Old October 7, 2011, 11:44 AM
I was thinking of getting a X6 1090T, a good cooler and ovc it all the way to 4 GHz, then do the Ubuntu trick with the VM player into fooling the clinetn I have 8 core to download and process bigadv, but I guess i shall wait for Dozer.
  #47 (permalink)
Old October 12, 2011, 11:43 AM
Glad I didn't bet the farm.
Let's revise that earlier formula to "Cores > threads for symmetric processes 9 times out of 10."
  #48 (permalink)
Old October 12, 2011, 12:24 PM
chrisk's Avatar
Folding Captain
I would laugh if this was not so sad.
Fold for team #54196
  #49 (permalink)
Old October 12, 2011, 12:53 PM
awww, 8-core MC chips might sit in a few rigs longer then planned....
QuadZilla & The Four Horsemen
Mining Bitcoins with: 7x6950, 3x5970, 7x5830, 2x5850
  #50 (permalink)
Old October 14, 2011, 03:51 AM
I have also seen an Asus KFSN40-DRE/SAS with two Opterons 2214 on ebay at 80$ here http://www.ebay.ca/itm/130584221943?...84.m1438.l2649
it would be good start as it has the heatsinks already, you need some registered ECC ram, DDR2, and later you can upgrade to some quad core opterons, on socket F, they are around 50$. You can start with regular SMP folding, then when you upgrade you can get on the -big adv units the right way without having to bend the rules, as I was thinking of doing it. I am thinking of that option too.
I am also interested in getting an HP Proliant DL585 G2 if I find one around locally. They are not that expensive in US but I don't know here.
i am getting a SUPERMICRO H8DME-2 OPTERON 2218 2GB COMBO to start my ventures in (more) cpu folding. i find my gpu folding setup too noisy for my taste. will upgrade later to a pair of Istanbul Opterons.
Can't Fold on GTX 460 geokilla HardwareCanucks F@H Team 8 March 23, 2011 06:14 PM
Using CPU to fold BrokenHalo83 HardwareCanucks F@H Team 2 April 19, 2009 10:42 PM
Why Fold? biff HardwareCanucks F@H Team 15 November 19, 2008 07:25 PM
Why do You Fold? Supergrover HardwareCanucks F@H Team 4 August 28, 2007 05:02 PM
