So 11.04 (or equiv.) is installed? Then all you're missing is xrdp (
Griffon's IT Library » Linux Ubuntu » Remote Desktop Connection against Ubuntu 10.10) to allow W7's Remote Desktop Connection to see the Linux box. You'll need the rig's name, the username you specified and the password associated with the account.
When I log into xrdp, I choose the "console" option. The password is created from the xrdp setup.
hfm works the same way. If you followed Musky's how-to, then you have created a "fah" folder. Here's how my hfm link looks like, with the computer name being FOLDING-LINUX:
\\FOLDING-LINUX\fah\
As for IPMI, you must connect a network cable to the appropriate network port (see manual) on the backpanel. Then from your router, find the ip address that was assigned to your IPMI port (using the MAC address will help). By default, BMC works via DHCP. Once found, use IE to connect to the IPMI webapp. I believe the username / password is admin / admin. From the app, you can control the rig, connect virtual DVD players, keyboard, mouse. Install Java, and you can access the BIOS live through the viewer.
Nice thing about BMC / IPMI is that as long as you have power to the board (but not powered up), IPMI will work. Power up, BIOS access and changes can be made Live without a kvm.
Any other questions, just ask.
edit: 6901 ppd from the Horsemen:
Project ID: 6901
Core: GRO-A5
Credit: 7164
Frames: 100
Path:
Number of Frames Observed: 300
Avg. Time / Frame : 00:11:06 - 133,227.1 PPD
Current WU being folded is also a 6901, and tpf is 10 min, 24 sec.
