  #81 (permalink)
Old October 19, 2011, 06:34 PM
PerryC's Avatar
So about a 9% increase in production (based on 80k ppd) for a 1 minute decrease in tpf....pretty good. Honestly wasn't expecting that much of a difference.
The oath to serve your country did not include a contract for normal luxury, and comforts enjoyed within our society. On the contrary it implies hardships, loyalty and devotion to duty, regardless of rank
  #82 (permalink)
Old October 19, 2011, 06:41 PM
Alpine's Avatar
just reboot and disabling the Powernow.... will see
BTW, here the final with my P6903 wu
Project ID: 6903
Core: GRO-A5
Credit: 22706
Frames: 100
Name: AMD 16 Cores
Path: \\192.168.88.244\Fah\
Number of Frames Observed: 100
Min. Time / Frame : 00:46:43 - 83*031,8 PPD
Avg. Time / Frame : 00:46:54 - 82*545,4 PPD
And now with a 6904 for now with a Power blah blah enable
Project ID: 6904
Core: GRO-A5
Credit: 31541
Frames: 100
Name: AMD 16 Cores
Number of Frames Observed: 17
Min. Time / Frame : 01:03:06 - 86*598,9 PPD
Avg. Time / Frame : 01:03:13 - 86*359,3 PPD
Cur. Time / Frame : 00:00:00 - 0,0 PPD
R3F. Time / Frame : 00:00:00 - 0,0 PPD
All Time / Frame : 00:00:00 - 0,0 PPD
Eff. Time / Frame : 01:04:05 - 84*613,3 PPD
Main system
|I7 3930K|Asus P9X79 WS|2X Evga GTX 690|Samsung 256G Pro|H100|Dominator Platinium 16GB 2133Mhz|AX1200|540 AIR|SP2500|Vengeance 2000|IBM PRO/1000 PT Quad Port|
Server system
|I7 3820|Asus P9X79|12G G.Skill 1600Mhz|Noctua NH-D14|Force 3 120GB|LSI megaRAID 9261 8|RAID5 5X 3TB|AX650|Fractal Design Arc Midi|IBM PRO/1000 PT Quad Port|
  #83 (permalink)
Old October 19, 2011, 07:58 PM
Alpine's Avatar
I gain ~ 1:30 in tpf....
I was a 1h3m 13sec Now 1h1m 31 secs PPD 89 556 = 3197 PPD more
Main system
Server system
  #84 (permalink)
Old October 20, 2011, 07:06 AM
Alpine's Avatar
after few hrs with PowerNow disable, i did have a drop of the tpf of 1 min 30 sec with the 2 first %. After that, tfp is going up at what i have before i remove it. (1h3m12secs). But im running bios 902 and not 2005 or somethiing like that
Main system
Server system
  #85 (permalink)
Old October 20, 2011, 04:20 PM
3.0charlie's Avatar
I think I have found the culprit: the kraken was not properly installed. I'll see after a few frames what the tpf is like.
Also, I bought a GT210 and dropped it in the case; but I'll need to dig deeper about setting this up to work with RDC
since all I have is a black screen with the Console Redirection (to change the BIOS settings), and Xorg has a hard
making connection.
So it's out. I'll play with it some more over the week-end, setting up a monitor closeby if needed.
Hydro-Quebec is salivating...
  #86 (permalink)
Old October 20, 2011, 06:56 PM
3.0charlie's Avatar
Hah! Beat that. 45:39 tpf.
  #87 (permalink)
Old October 20, 2011, 07:10 PM
Alpine's Avatar
Crap 1 min faster WOWWW .. congrats !!
I think i really need to update the bios !!!
Main system
Server system
  #88 (permalink)
Old October 22, 2011, 11:43 AM
Shadowmeph's Avatar
I was surfing around today and stumbled across a review on the KGPE-D16 motherboard I found it fairly interesting especially the tweaks this person used .I am wondering if the actually would be worth trying.
How fast are dual AMD Opteron 6128 G34 processors in the ASUS KGPE-D16? - Asus KGPE-D16 Dual Socket G34/ AMD SR5690/ V&2GbE/ SSI EEB Server Motherboard KGPED16ASMB4IKVM - Epinions.com
  #89 (permalink)
Old October 22, 2011, 02:38 PM
3.0charlie's Avatar
Interesting. So:
Disable The On-Board Graphics Card And Get A PCI-e x16 Video Card!
and
you should shut off the following under the Memory Configuration screen in your KGPE-D16 bios: Channel Interleaving, Bank Swizzle Mode, Node Interleaving, CS Sparing Enable
I'll check those BIOS options tomorrow.
  #90 (permalink)
Old October 23, 2011, 09:35 AM
3.0charlie's Avatar
Update with a 6903: tpf of 45min 06sec (87242 ppd)... with no other changes. I've yet to check out the BIOS settings, since I don't want to screw up this WU...
