Originally Posted by Shadowmeph The newer linux OS systems really don't have that many issues with Graphics cards at the most you might have a bit of playing around if you use an ATI card but even then if you have problems ( which I used to) just go to the linuxquestions.org site and you most likely will get all your answers there.
I actually have a question about watercooling this type of system, coul;d someone just use a standard cpu watercooling blockas long as you have the proper plates ( block plate and back back) . also if this can be done do you think a duel rad would be enough to cool both cpus? |
Since oc'ing is not possible (well, it is with Extra Spicy chips but g'luck finding some), the heat load is very low. Wc'ing is not required since the high-end HSFs (Noctuas) are so efficient, and silent. And
Originally Posted by stoanee I love the way this thread has taken on a life of its own, reminds me of the SR2 thread of not so long ago.  |
This is a great system for ppd/watts performance and low price.
