  #61 (permalink)
Old October 16, 2011, 07:20 PM
Alpine's Avatar
3.0Charlie: Do you use the onboard video card? If so, I found that had a slightly slower cpus. This is maybe why you have a TPF higher than me
• ► › I7 3930K|Asus P9X79 WS|Evga GTX 690 Signature|Corsair Force 3 120GB|Corsair H1000|Corsair Dominator Platinium 16GB 2133Mhz|
Corsair AX1200|Corsair 600T SE|Corsair SP2500|Corsair Vengeance 2000
• ► › I7 2600K @ 4.9Ghz|P67A-UD4-B3|12G G.Skill 1600Mhz|Noctua NH-D14|OCZ Vertex 2 60GB|EVGA GTX 580 SSC|Corsair AX650|Lancool PC-K62|
  #62 (permalink)
Old October 17, 2011, 05:10 AM
3.0charlie's Avatar
Yes and no - I use Remote Desktop Connection for GUI access. Or there is a BIOS setting that's different.
Time to buy 2 cheap, fanless GPUs me thinks...
  #63 (permalink)
Old October 17, 2011, 09:14 AM
Dead Things's Avatar
This is interesting. Keep us posted on your results if you go through with this 3.0!
Join the PPD revolution!
Proud to be Folding @ Home
deadthings @ Team 37412
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
  #64 (permalink)
Old October 17, 2011, 09:26 AM
3.0charlie's Avatar
Which low-power GPU manufacturer behaves better with a Linux OS? Team Green, or Team Red? Also, the Onboard chip is from ASpeed, which is a stand-alone (inbedded) chip. I don't think it should have an impact on the CPU usage. Then again, I could be wrong.
  #65 (permalink)
Old October 17, 2011, 09:33 AM
chrisk's Avatar
Folding Captain
I'm using a GTX460 with Ubuntu and never had an issue, so I would think you are good with the green team.
Fold for team #54196
  #66 (permalink)
Old October 17, 2011, 10:16 AM
Alpine's Avatar
I have install a Evga GTX460 without any problem and running smoothly
  #67 (permalink)
Old October 17, 2011, 10:37 AM
Ditto for GT240 and 8600GT here.
  #68 (permalink)
Old October 17, 2011, 10:47 AM
Soultribunal's Avatar
nVidia for sure.
-ST
  #69 (permalink)
Old October 17, 2011, 10:49 AM
Shadowmeph's Avatar
The newer linux OS systems really don't have that many issues with Graphics cards at the most you might have a bit of playing around if you use an ATI card but even then if you have problems ( which I used to) just go to the linuxquestions.org site and you most likely will get all your answers there.
I actually have a question about watercooling this type of system, coul;d someone just use a standard cpu watercooling blockas long as you have the proper plates ( block plate and back back) . also if this can be done do you think a duel rad would be enough to cool both cpus?
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
  #70 (permalink)
Old October 17, 2011, 11:06 AM
stoanee's Avatar
I love the way this thread has taken on a life of its own, reminds me of the SR2 thread of not so long ago.
heatware
