Old September 23, 2011, 05:05 PM
3.0charlie's Avatar
Alright, alright, alright.
Parts are in sig.
Per HFM, numbers after 20% completion: 6904 R0, C17, G20. tpf 1 hour, 3 minutes, 59 seconds. ppd 84 370. Credit: 374 880.
My 4p rig was folding a 6904 yesterday, and its tpf was 32 minutes. Nice, perfect scaling. I don't remember the ppd, but the credit was 524 527.
Rundown:
Board: 420
Chips: 250 each
Ram: 17 each, 8x
HSFs: Can't say, Premier Partner at NCIX. But damn, damn cheap compared to Newegg. See, damn is written twice...
PSU 160
More tpf and ppd in 3 days, once the 6904 is complete.
DT, I don't have a W7 readily available to play with Wprime. I'll see what I can do over the week-end.
Hydro-Quebec is salivating...
Old September 23, 2011, 09:48 PM
Alpine's Avatar
at that price i think i will build one
Main system
|I7 3930K|Asus P9X79 WS|2X Evga GTX 690|Samsung 256G Pro|H100|Dominator Platinium 16GB 2133Mhz|AX1200|540 AIR|SP2500|Vengeance 2000|IBM PRO/1000 PT Quad Port|
Server system
|I7 3820|Asus P9X79|12G G.Skill 1600Mhz|Noctua NH-D14|Force 3 120GB|LSI megaRAID 9261 8|RAID5 5X 3TB|AX650|Fractal Design Arc Midi|IBM PRO/1000 PT Quad Port|
Old September 24, 2011, 05:40 AM
stoanee's Avatar
Do it!!
heatware
Old September 24, 2011, 06:53 AM
Alpine's Avatar
I will do, but i need to sell some hardware before...
Main system
Server system
Old September 24, 2011, 07:25 AM
stoanee's Avatar
Maybe we need to do a bulk purchase for the team.
heatware
Old September 24, 2011, 06:04 PM
3.0charlie's Avatar
lol
Indeed, ppd is great for such a low price. Can't wait to see the power consumption of that rig, once I transfer it from its cardboard box to the server case.
ppd/watt is where the money is. Add low noise and temps in the mix, this is a sure winner combo.
Old September 25, 2011, 05:56 AM
MARSTG's Avatar
just to make it overkill you could add 2 nvidia gpus
Old September 25, 2011, 06:34 AM
Alpine's Avatar
Hey 3.0, With this kind of mahcine, are you able to do some OC and getting more PPD ?
Main system
Server system
  #19 (permalink)
Old September 25, 2011, 06:59 AM
stoanee's Avatar
Usually it is not worth running gpu folding on a smp rig, It steals cpu cycles, lowering ppd, consumes more power, produces much heat and noise from running gpu fans high.
If you want a gpu rig go with low end cpu, lots of pcie slots and good cooling for case.
heatware
  #20 (permalink)
Old September 25, 2011, 02:02 PM
3.0charlie's Avatar
Unfortunately, no. Overclocking is not possible, unless Extra Spicy chips are used.
What he said. bigadv WUs have an exponential credit calc.
