  #121 (permalink)
Old November 2, 2011, 10:52 AM
Entz's Avatar
Thanks for the thread, it was the reason I put together a 2P G34 system and has been very useful in the tweaking department.
Moved from ext4 to ext3.
Im guessing that is about the best one can get
  #122 (permalink)
Old November 2, 2011, 11:19 AM
Shadowmeph's Avatar
This question might seem a little "not intelligent" but how do you load the Non VMed folders into HFM.Net? I have no problems Loading in the vmed clients , but if I install Linux and then install Fah I can never get it load up in HFM.net if it is on a different PC.
  #123 (permalink)
Old November 2, 2011, 11:29 AM
Entz's Avatar
You need to install Samba and "share" a folder. It will then be viewable from a windows PC like any network share would be ( i.e. \\jarvis\FAH )
  #124 (permalink)
Old November 2, 2011, 11:57 AM
3.0charlie's Avatar
Crap - my best is 45:06...
Right-click on the fah folder - Sharing Options - Check the Share This Folder checkbox - it will prompt you to install a package, let it install. It will want you to restart your session, don't yet. Click Cancel on the sharing box.
Reboot the machine. When you log back in, go back to Places - Home Folder, right-click your fah folder and select Sharing options, and check all three checkboxes. You will get something about adding permissions, click OK.
Hydro-Quebec is salivating...
  #125 (permalink)
Old November 2, 2011, 03:05 PM
Shadowmeph's Avatar
Sounds pretty easy Cool ty
  #126 (permalink)
Old November 2, 2011, 04:48 PM
Alpine's Avatar
Im starting to hate my 8.2.
Since last week, i have lost 2 or 3 6903 wu. I was suppose to complete one today around 17hrs. I just check and it was crash since last night. Same as the last time and i don't remember the other if PC have crash or what.
Im using stock setting in my bios...
I think its time for me to re-install Ubuntu with the EXT3....
Main system
|I7 3930K|Asus P9X79 WS|2X Evga GTX 690|Samsung 256G Pro|H100|Dominator Platinium 16GB 2133Mhz|AX1200|540 AIR|SP2500|Vengeance 2000|IBM PRO/1000 PT Quad Port|
Server system
|I7 3820|Asus P9X79|12G G.Skill 1600Mhz|Noctua NH-D14|Force 3 120GB|LSI megaRAID 9261 8|RAID5 5X 3TB|AX650|Fractal Design Arc Midi|IBM PRO/1000 PT Quad Port|
  #127 (permalink)
Old November 2, 2011, 05:00 PM
3.0charlie's Avatar
Yes, and make sure the ECC is disabled in the BIOS. By the same token, run Memtest+86 just to be sure...
  #128 (permalink)
Old November 2, 2011, 05:03 PM
Alpine's Avatar
Im installing windows, right now, on a second HDD . So im gonna test the stability with wndows.
Memtest .. good idea
Thanks Mr Charlie!
Main system
Server system
  #129 (permalink)
Old November 2, 2011, 05:20 PM
3.0charlie's Avatar
Dammit. So close! Btw, for which Team do you fold?
  #130 (permalink)
Old November 2, 2011, 05:37 PM
Entz's Avatar
Mine is at 44:37 right now so there is a bit of variance, i would consider ~2s even :-)
Currently folding for NCIX
Alpine memtest is a very good idea, as is maybe pulling it of your case and making sure nothing is shorted. That shouldnt be happening. Are you backing up your Wu's?
