  #111 (permalink)
Old November 1, 2011, 03:48 AM
3.0charlie's Avatar
You need 4 sticks per cpu bank for quad-channel performance.
Hydro-Quebec is salivating...
  #112 (permalink)
Old November 1, 2011, 09:25 AM
Dead Things's Avatar
Originally Posted by Shadowmeph View Post
that Motherboard is allot bigger then I thought that it would be I am not sure where I am going to put it lol.
Don't worry - it's just SSI-EEB, a standard form factor compatible with almost every EATX case. In fact, I can't think of any EATX cases with which it wouldn't be compatible.
And yeah - as 3.0charlie said, you want quad-channel to maximize bandwidth. Amount of RAM isn't important - even 8x1GB would be good to go for a DP G34 rig.
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
Follow my benching, folding, mining and miscellaneous shenanigans @dt_oc
  #113 (permalink)
Old November 1, 2011, 09:28 AM
Shadowmeph's Avatar
hmm good to know So I should have stuck with charlies idea of buying Kingston 8x 1Gb, thing is the ram I bought was a such a good deal I just couldn't resist hehe.
as for the case my oridgingal idea was to take one other the many old cases and just drill a new hole or two but I am thinking I might have to buy a new case instead.
  #114 (permalink)
Old November 1, 2011, 09:49 AM
Alpine's Avatar
Shadow: Im running with only 4 bank or memory for both CPU and it run fine. That's maybe why i do have a higher TPF than Charlie.
Main system
|I7 3930K|Asus P9X79 WS|2X Evga GTX 690|Samsung 256G Pro|H100|Dominator Platinium 16GB 2133Mhz|AX1200|540 AIR|SP2500|Vengeance 2000|IBM PRO/1000 PT Quad Port|
  #115 (permalink)
Old November 1, 2011, 10:25 AM
Entz's Avatar
It can make a pretty big difference.
I was running my 2P 6128 with only 4 sticks of ram (DC 2 per proc) and finally got the other 4 in the mail yesterday so I have some numbers.
{Was some numbers here}
Edit: Never mind looks like I disabled C1E between runs so that is likely the biggest contributor, more than the extra ram.
  #116 (permalink)
Old November 1, 2011, 11:29 AM
Regardless, the PPD premium associated with memory bandwidth on the G34 platform has been well-established. It was a particularly interesting discovery in light of the fact that memory bandwidth has had little to no impact on PPD with any previous platform.
  #117 (permalink)
Old November 1, 2011, 12:00 PM
Entz's Avatar
Indeed. Between Quad channel and C1E off I gained 15k PPD. Which is very amazing to say the least. I would guess Quad channel added about 5-10%... Might require more testing :)
How much of an issue is the checkpoint process? i.e. Is it worth folding on a ramdrive or even a SSD for a bit extra PPD or not worth the hassle?
  #118 (permalink)
Old November 1, 2011, 01:38 PM
As long as you're using an ext3 filesystem, there's essentially nothing to be gained from using an SSD or RAMdisk anymore. If using ext4, you'd benefit from it - but you would still come up short in relation to ext3 on a mechanical drive.
  #119 (permalink)
Old November 1, 2011, 02:17 PM
Entz's Avatar
Exclamation
Thanks DT!
Ugh: It seems when I installed Ubuntu it set it up as ext4. Time to reformat!
  #120 (permalink)
Old November 1, 2011, 06:01 PM
3.0charlie's Avatar
Both rigs are running on SSDs, and I don't see any advantage over HDDs.
