  #31 (permalink)
Old September 23, 2011, 07:01 AM
3.0charlie's Avatar
Yes, and yes.
John
  #32 (permalink)
Old September 23, 2011, 02:39 PM
prokaryote's Avatar
Right, off to go get a tap and die set.
Thanks John.
Dan
  #33 (permalink)
Old September 27, 2011, 03:00 PM
3.0charlie's Avatar
Originally Posted by 4DoorGTZ View Post
No extra spicey chips here but I was able to undervolt my chips at stock speeds (read sig) with TPC
Using TPC? I tried the following:
Code:
sudo modprobe msr
sudo modprobe cpuid
sudo TurionPowerControl -set core all pstate 0 vcore 1.05
sudo TurionPowerControl -l
-l shows the correct vcore (1.05V), but I do not see a drop in both temps and Watts pull from the wall on either the 2p, or the 4p rig.
Which code did you use? Or am I missing an "Apply" command? Mind you, I'm a complete Linux noob.
  #34 (permalink)
Old September 27, 2011, 10:30 PM
linux noob here too. If I recall (set it up months ago and havent touched it) what you did looks right, but when you change any parameters for any of the pstates it doesnt take effect right away. You need to switch out of that pstate, and then back into it. Or switch out of it, then make the changes and switch back into it. Also there was a modified version of TPC by sfield linked over on amdzone in one of those threads, original tpc is for single socket applications, I believe the modified version adapted it to work on 2p/4p (again, months ago when I set it up I knew where to look, not so much anymore)
QuadZilla & The Four Horsemen
Mining Bitcoins with: 7x6950, 3x5970, 7x5830, 2x5850
  #35 (permalink)
Old September 28, 2011, 04:14 AM
3.0charlie's Avatar
I remember now reading something to that effect - and I do have the sfield-modified TPC installed. I'll check again tonight.
  #36 (permalink)
Old September 28, 2011, 02:28 PM
3.0charlie's Avatar
Thank you much, the correct code to switch states is
Code:
./TurionPowerControl core all -fo 1 pstate 1
then
Code:
./TurionPowerControl core all -fo 1 pstate 0
to force it back to 100%. Worked like a charm, the Four Horsemen dropped power consumption from 490ish Watts to 440ish Watts - going from 1.2V Vcore to 1.05V Vcore.
  #37 (permalink)
Old September 28, 2011, 03:02 PM
prokaryote's Avatar
All of the gallop on 9/10 of the hay!
  #38 (permalink)
Old September 28, 2011, 03:09 PM
3.0charlie's Avatar
Yup! And I'll try 1.0V later this evening.
  #39 (permalink)
Old September 28, 2011, 05:14 PM
My 6176's crapped out after a few hours at 2.3 and 1.0v, but been running for months with 1.05v, you're might do 1 or less.... I recall someone from amdzone running 0.85v but cant remember what chips.
  #40 (permalink)
Old September 28, 2011, 08:24 PM
Dead Things's Avatar
In case you guys didn't already know this - the official TPC release has merged code from blackshard, sfield and tear since v0.40a. The latest is v0.41. TurionPowerControl - Home
Join the PPD revolution!
Proud to be Folding @ Home
deadthings @ Team 37412
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
AMD Ships First "Interlagos" CPUs based on Bulldozer [VR-Zone] EmptyMellon Reviews & Articles from the Web 1 September 7, 2011 12:04 AM
Sandy Bridge Based Xeon's E3/E7, up to 10cores/20threads 4DoorGTZ Press Releases & Tech News 4 April 7, 2011 05:52 PM
Future of xeon processors? napier Rumor Mill 6 July 10, 2009 12:03 PM
Advice on Future System vintank Water Cooling 3 January 3, 2009 06:58 PM
xeon Rapid-X CPU's and Motherboards 17 March 9, 2008 05:07 AM
