-   HardwareCanucks F@H Team (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/)
-   -   xxx9999999 workframes ? (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/46287-xxx9999999-workframes.html)
BrainEater September 7, 2011 06:36 PM
I just had my two gpu3 rig's essentially error out .....they went to xxx.99999 workframes then died , sent my 580's into full fan mode and everything.
Anyone see this ?
BrainEater September 11, 2011 06:56 PM
No one eh ?
It hasnt happened again , it was just odd both rigs did it at the same time.
:thumb:
3.0charlie September 11, 2011 07:00 PM
Probably bad WUs pulled from the same server.
Or a simple hick-up from your PSU.
Shite happens.
BrainEater September 30, 2011 05:50 PM
hmmmmm
Ok , I have caught the machine in the act...
Here's what you first see ;
http://braineater.kicks-ass.tv/miscshite/999one.jpg
The last time I saw this , the rig just died....Now , it actually keeps going , and will return positive results to stanford.
However , if you stop the client , you will get this :
http://braineater.kicks-ass.tv/miscshite/999two.jpg
Then If you restart , you get this :
http://braineater.kicks-ass.tv/miscshite/999three.jpg
At this point you need to delete the std files and start from scratch.
Seems to me it's a flakey unit but .....
Edit : As far as I know "Client Died" is not a positive outcome....
:haha:
3.0charlie September 30, 2011 06:04 PM
I don't even remember reading about that. Ever.
chrisk September 30, 2011 06:06 PM
The fahwiki says this could be due to bad memory/or timings issues:
Common Error Messages - FaHWiki
Tried memtest? I know its a GPU unit but give your rig's memory a check with 1-2 passes.
BrainEater September 30, 2011 06:12 PM
I havnt tried memtest but I will.....this is a 'formerly' stable rig ...no OC etc....
:thumb:
chrisk September 30, 2011 06:13 PM
:thumb:
The fact that you had this issue on two rigs makes me doubt this resolution but stranger things have happened.
BrainEater September 30, 2011 06:17 PM
Yep....that's what makes me think workunit...
Mebbie stanford is crunching 'Hulk' genes....who knows....it's odd they return correctly.
:thumb:
Dead Things September 30, 2011 07:29 PM
:shok: Oh my god, they killed Client!
You bastards!
