<~----> HCF F@H discussion - Page 10 - Hardware Canucks
  #91 (permalink)
Old January 28, 2008, 02:05 PM
elninio's Avatar
im in, amd 64 3500+ with 512 ram, going 2p quad core xeon on triple rad wc and as much ram as i can afford in the summer
  #92 (permalink)
Old January 29, 2008, 02:21 PM
Bah, my sig rig is out of commission. Either PSU or CPU.... havent got the time to fiddle with it.
QuadZilla & The Four Horsemen
Mining Bitcoins with: 7x6950, 3x5970, 7x5830, 2x5850
  #93 (permalink)
Old January 29, 2008, 02:45 PM
sswilson's Avatar
Ouch.....
GL with that. Hope it's not the CPU.......
On another note to all... have a look at your XP folding machines.... there was an update or something today and I found mine locked up when I checked it this afternoon.
  #94 (permalink)
Old January 29, 2008, 03:49 PM
3.0charlie's Avatar
3 rigs out of 5 are out since last night. I just can't find out what's wrong. Says can't connect to the Server. But when I ping it, answers right back....
  #95 (permalink)
Old January 29, 2008, 04:19 PM
sswilson's Avatar
Not sure what to suggest if a ping is returning ok.
I'm assuming you reboot everything to see if it was a network issue.....
Looking at FahMon it's obvious that it was indeed hung (screensaver on XP wouldn't unlock so I couldn't see what was going on on-screen) it's chugging along fine now but we'll have to wait for 5 hrs+ to see if I have any luck uploading the WU.
There are some servers listed as fail here..... Folding@Home server status , but using their methodology of testing (report as fail if they can't ping it) wouldn't report the servers you're trying to get to as a fail since you can ping them.
Are you still chugging along, but just can't upload finished WUs?
  #96 (permalink)
Old January 29, 2008, 06:16 PM
3.0charlie's Avatar
The rigs couldn't d/l the new WUs. Upload was fine though for the last WUs. No network issue, full reboot on both rigs - FAH re-install even. Still no luck. So I shut down everything, went out for supper. Just came back, fired both rigs.
It works. Don't know how, don't know why, it just does.
Go figure. Lost 24hrs...
  #97 (permalink)
Old January 31, 2008, 01:40 PM
SugarJ's Avatar
Default 50% usage on Core 2
Since my system is on almost all the time, I decided to do a little Folding and help the team out.
But, my CPU utilization maxes out at 50%. Do I have to run 2 instances from separate folders (1 for each core) ?
Cheers,
Gord
  #98 (permalink)
Old January 31, 2008, 01:52 PM
3.0charlie's Avatar
With a Dual Core, you'll have the best production using the SMP Client, shown as "Windows 2000/XP/Vista SMP client console version 5.91 beta" on the FAH download page. It's the last client of the High-performance Windows section.
Or you can install the same second client that you already have, but in a different folder. Also if you do so, make sure that the Machine ID is different from both clients - ie. 1 and 2.
  #99 (permalink)
Old January 31, 2008, 01:55 PM
Cptn Vortex's Avatar
Getting a second Quadcore system tomorrow! Put together by crazyea from Xtremesystems/NCIX! Going to put that thing to work folding too!
The Titan - XtremeSystems Forums
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
  #100 (permalink)
Old January 31, 2008, 02:02 PM
3.0charlie's Avatar
Great! The more, the merrier!
(but on a side note, I don't like that bend at the pump outlet...)
Antec TPQ Problems Discussion Thread enaberif Power Supplies 27 March 13, 2008 04:10 PM
Phenom Preview Discussion Thread Misoprostol CPU's and Motherboards 34 December 14, 2007 01:00 AM
Thermalright XWB-1 Review Discussion Thread Misoprostol Water Cooling 11 October 25, 2007 07:53 PM
GPU Round Up Discussion Thread Misoprostol Water Cooling 18 July 17, 2007 06:22 PM
