  #71 (permalink)
Old September 7, 2011, 06:53 PM
I'll pull over onto the shoulder for you in 3.5 weeks.
  #72 (permalink)
Old September 7, 2011, 06:54 PM
chrisk's Avatar
Folding Captain
Originally Posted by lechumbl View Post
Hi Chris,
Actually, I was talking about Dan, I can never catch you....................yet.
Take care..............
No worries. The more that can try to catch me the better. Dan says he will still keep folding!
Fold for team #54196
  #73 (permalink)
Old September 7, 2011, 07:09 PM
lechumbl's Avatar
Hi all,
Tomorrow, I will have more power in my systems for greater glory for the team.
Don't want to spoil the surprise tho.
Take care, and don't pull over, I will leave very tiny footprints on your back, Ogdin......
Regards,
Lee
* F@H Unit Points *
  #74 (permalink)
Old September 8, 2011, 05:22 PM
lechumbl's Avatar
Hi all,
Well, cancel the surprise, an Asus P6T Deluxe V2 mobo I ordered arrived and it was not working.
I have RMAed it but will be a couple weeks for the replacement to get here.
I have to use a Sabertooth mobo till then.
Points will drop for a while, but "I shall return." Yes, I borrowed that line
Take care.........
Regards,
Lee
* F@H Unit Points *
  #75 (permalink)
Old September 8, 2011, 06:23 PM
DOA parts are never fun - hopefully the turn-around time is fast!
As a side note, when you do overtake me I won't pull over but you may have to avoid the smokescreen from my overclocked Phenom on a MA770-UD3...
See: Let's go Team !!
I'm knowingly exceeding the ratings on the CPU (max temperature by 5C) and cooler (max thermal dissipation by 5-10W or so) to get that extra ~300 PPD
  #76 (permalink)
Old September 8, 2011, 06:28 PM
chrisk's Avatar
Folding Captain
Sounds like fun frontier!
Sorry to hear about the doa part Lee...thats always disappointing.
  #77 (permalink)
Old September 8, 2011, 06:32 PM
lechumbl's Avatar
Hi all,
Ya, DOAs suck, but I get to get excited again when it arrives again.
Take care.........
Regards,
Lee
* F@H Unit Points *
  #78 (permalink)
Old September 8, 2011, 07:16 PM
MARSTG's Avatar
Finally made it to top 100!
  #79 (permalink)
Old September 8, 2011, 07:56 PM
lechumbl's Avatar
Hi MARSTG,
Congrats!!
Take care.........
Regards,
Lee
* F@H Unit Points *
  #80 (permalink)
Old September 13, 2011, 01:26 PM
lechumbl's Avatar
Default SMPs Dying
Hi all,
Well, I have had 3 different -bigadv units die in various stages of completion.
I am not too much O/C'd, but backed down a little anyway, worth a try.
Thought at first, it might be bad units, but I don't think 3 in a row are bad tho .
Time will tell.
Anyone else having this prob?
Regards,
Lee
* F@H Unit Points *
i broke a wire - help hfxmike Troubleshooting 13 November 5, 2010 11:33 AM
G15 broke Nemaster203 Peripherals 18 December 18, 2009 11:24 PM
Water line broke and then anouther line broke muse108dc Off Topic 3 March 28, 2009 07:34 AM
Broke Asrock X48? SugarJ CPU's and Motherboards 4 September 23, 2008 09:48 AM
Just broke 100 K this weekend! zlojack HardwareCanucks F@H Team 4 May 19, 2008 06:53 PM
