Old July 17, 2011, 11:09 AM
SKW's Avatar
SKW SKW is offline
Default question about hardware
Hello fellow folders,
here is my question. I'm currently running a 6950 as my card for gaming and such. Am i able to put a gtx 460 in my machine and just fold with it?
Thanks
SKW
Old July 17, 2011, 11:50 AM
lowfat's Avatar
Yes you can.
Old July 17, 2011, 12:09 PM
SKW's Avatar
SKW SKW is offline
sweet, thanks! (does the 1gb vs the 768mb differ in points that much?)
Now hopefully one comes on the forum for a good price :P
Old July 17, 2011, 12:10 PM
yup.
just make a shortcut on your desktop,right click properties, gpu -1 if it is the second one.
-2 if 3rd and so forth
Old July 17, 2011, 12:25 PM
lowfat's Avatar
There is a small difference between the 768MB and 1024MB in terms of folding capability due to the extra shaders but nothing huge.
Old July 17, 2011, 05:59 PM
SKW's Avatar
SKW SKW is offline
Ok thanks. I will look for both.. Any certain make that is better?
Old July 17, 2011, 06:00 PM
try to dig a card that 1-doesn't squeal and 2-that outputs outside the case unless
you run your puter on a test bench 24/7..like old man dan here
Old July 17, 2011, 06:38 PM
supaflyx3's Avatar
if you plan to overclock, try to get a twinfrozr II card.
Question about older game(F.E.A.R) and hardware fourthman Gaming 8 February 16, 2011 09:34 AM
CPUID Hardware Monitor - temps question somecanadianguy Overclocking, Tweaking and Benchmarking 8 June 16, 2009 05:11 PM
