<~----> Started folding, not going to break any records - Hardware Canucks
Old April 30, 2011, 07:18 AM
PerryC's Avatar
Default Started folding, not going to break any records
Started folding on my Dell early this morning, definitely not going to be breaking any records though....about 30% complete the first unit about 10 hours in.
Old April 30, 2011, 08:02 AM
nice. just watch out for the temp spikes. laptops are not that great heat runners,usually.
Old April 30, 2011, 09:00 AM
chrisk's Avatar
Folding Captain
Thanks for helping out the fight and the team!
BTW is it a laptop? I tend to avoid folding on a laptop to prevent heat issues.
Fold for team #54196
Old April 30, 2011, 03:03 PM
PerryC's Avatar
Its my Dell E520 desktop, using my laptop to do my surfing. E6300 @ 1.86 Ghz dual core, so nothing outrageous. I do have 2 instances of f@h running right now....both at about 53%. Not sure if its the same workunit, or it is actually two seperate. I'll guess I'll find out when they get turned in.
Old April 30, 2011, 03:07 PM
hmm..better run 2 timeless units. crap ppd, but for sure you wont run out of time lol.
gives you an idea how things work,so all is good.
your new system will do a bit more, i reckon...:)
Old April 30, 2011, 04:02 PM
PerryC's Avatar
I just plan on letting it run 24/7, so it will keep producing steadily. Heat isn't that a big an issue since it sits in one of the coolest rooms in my place. The only time it won't be folding is if I am doing some gaming, which lately hasn't been that frequent. Once the new build gets squared away then the old will ony be used for folding.
Old April 30, 2011, 04:20 PM
cool,but i think it'd be kinda wasting energy with the ppd that system produces. any is appreicated, but bang per watt,not good :)
Old April 30, 2011, 05:25 PM
It's only a 65W TDP, it'll be like leaving 1-2 incandescents on most of the time. Inefficient but not a waste.
Old April 30, 2011, 06:30 PM
It would do better with one instance of smp client instead . It will run 100% of both cores
Old May 1, 2011, 01:47 AM
right,how about making it a fileserver or such? worth to keep it online :)
90 000 US Military Records Disclosed Online Kommie986 Off Topic 10 July 26, 2010 10:44 AM
Started folding Unknownm HardwareCanucks F@H Team 3 September 11, 2009 07:09 PM
started folding, finally :P Putz HardwareCanucks F@H Team 10 September 10, 2009 04:49 PM
I Started Folding Tonight. Spikemaul HardwareCanucks F@H Team 34 May 22, 2009 10:34 PM
Did M$ go out of their way to break GMail with the last update??? sswilson O/S's, Drivers & General Software 10 September 12, 2008 08:08 PM
