  #31 (permalink)
Old April 5, 2011, 02:56 PM
G777's Avatar
I'm back Home, and I just checked. I have the same information showing in the Network and Sharing Center. Both VMware adapters are in the public area. There has to be something else.
edit: in the web config, I have changed the Workgroup to be the same as my network, and DHCP is enabled. In the Player settings, the Adapter is Connected, Connect at Power On and Bridged, with "Replicate" unchecked. In HFM, the path is
Thanks again for the info, I will have another look when I get home tonight. Maybe I'll let it finish a WU before I start screwing with it this time...
_______________________________________________
HWC Overclocking Team, breaking hardware for fun!
Team Thread
  #32 (permalink)
Old April 5, 2011, 03:03 PM
3.0charlie's Avatar
Weird, the path did not show. It's .
  #33 (permalink)
Old April 5, 2011, 03:08 PM
G777's Avatar
I don't recall changing or entering any workgroup info, maybe I left it blank in the web config and that's causing the host to not "see" the virtual network.
Team Thread
  #34 (permalink)
Old April 8, 2011, 07:00 PM
G777's Avatar
Default Update:
Finally able to get HFM working with the VM Player Turned out my network adapter was missing the microsoft network client... man that was a PITA!
Thanks all for the help and suggestions, first WU was only smp but hopefully there'll be some bigadv coming my way soon
Team Thread
New Old Folder.. mchutch HardwareCanucks F@H Team 7 February 27, 2011 08:01 PM
Fail to get work on linux CPU client? martin_metal_88 HardwareCanucks F@H Team 9 June 6, 2010 06:26 PM
Low Consumption Folder OR Part time POWER Folder ilya New Builds 3 May 16, 2010 03:33 PM
Attempt #10 to get work failed, and no other work to do. LaughingCrow HardwareCanucks F@H Team 3 May 5, 2010 08:29 AM
Folder down redwagon HardwareCanucks F@H Team 2 October 2, 2009 12:35 PM
