Old April 4, 2011, 07:32 PM
Alpine's Avatar
so.... are you lucky and finally got a Bigadv under Vm ?
Main system
|I7 3930K|Asus P9X79 WS|2X Evga GTX 690|Samsung 256G Pro|H100|Dominator Platinium 16GB 2133Mhz|AX1200|540 AIR|SP2500|Vengeance 2000|IBM PRO/1000 PT Quad Port|
Server system
|I7 3820|Asus P9X79|12G G.Skill 1600Mhz|Noctua NH-D14|Force 3 120GB|LSI megaRAID 9261 8|RAID5 5X 3TB|AX650|Fractal Design Arc Midi|IBM PRO/1000 PT Quad Port|
Old April 4, 2011, 07:56 PM
G777's Avatar
Not feeling too lucky, tried web config, tried manual config. Cannot get HFM to work, accidentally reset the freakin VM and it wanted to re-configure... so I lost my 6901 and was rewarded with a 2684
I'm having a want to punch the monitor and smash the keyboard over the case moment. Need a drink... What the heck am I doing wrong here?
_______________________________________________
HWC Overclocking Team, breaking hardware for fun!
Team Thread
Old April 4, 2011, 08:00 PM
Alpine's Avatar
you need to start folding before loading in HFM.
edit: ooopsss.... you're already folding
Main system
Server system
Old April 4, 2011, 08:03 PM
G777's Avatar
It is folding, just not displaying it. 92% cpu usage..
Team Thread
Old April 4, 2011, 08:11 PM
chrisk's Avatar
Folding Captain
Instead of typing in the IP address in the "Log Folder" box, can you click the 'browse' button next to it, and try navigating to it manually? You shoulod see a computer listed in your network called "FAH"...if you do, select it and then the fah folder.
Also, try getting rid of the last \ you have at the end of the folder location.
Fold for team #54196
Old April 4, 2011, 08:29 PM
G777's Avatar
Ah, see there's the problem. There isn't another machine in the network, there's no virtual network adapters... nothing. I figured it was a windows 7 network setting I'm not grasping... what I don't get is how the VM would connect to the assignment server to download a work unit???
Team Thread
Old April 4, 2011, 08:36 PM
chrisk's Avatar
Folding Captain
It could be a windows issue but not sure...you said you could access the web server by typing in the ip address of the client, so it makes no sense that it can see one folder (the files in the root of the ip that allow you web access), but no access to the fah files. Did taking the backspace off the log folder like I mention make any difference?
Old April 4, 2011, 08:58 PM
G777's Avatar
Tried getting rid of the backspace, I'm not actually putting it there. HFM enters it as soon as I hit ok, so it's there if I open "edit client". I tried network adapter set to bridge and nat to see if that would show the FAH VM on my network, but no. Network discovery is on... head hurts.
One thing comes to mind, about a week ago when I tried to get it to work, I couldn't get an id or connect to the assignment server. I tried a bunch of different things including deleting the virtual network adapters (there were two) that showed in device manager from when I ran it a month ago. Gotta be something wacky with my windows network settings that I screwed up
Team Thread
  #19 (permalink)
Old April 5, 2011, 04:18 AM
3.0charlie's Avatar
You can add the VM Network adaptors if you deleted them via the Options / Add settting in VM Player. Also in the setup, choose NAT - not Bridge.
Once setup, it can take a long time for HFM to show the data. I have seen on mine 0% for a long time, then 10% all of a sudden; actual ppd numbers were seen once the folding was past 50% completed (whatever options I selected in the HFM configuration).
Hydro-Quebec is salivating...
  #20 (permalink)
Old April 5, 2011, 05:16 AM
G777's Avatar
I deleted the network adapter in device manager, managed to get them back by re installing the VM Player. I decided to start fresh with a new image and set VM to NAT again...used the web config but I don't believe HFM is working. Usually there will be a colour on the status bar for the client, even if the tpf hasn't registered yet, it'll register as stopped or hung even when the client is not working.
Again, I must be missing something obvious here. There's no virtual network showing, the virtual adapters show no interet access- but the client can download a work unit???
Team Thread
New Old Folder.. mchutch HardwareCanucks F@H Team 7 February 27, 2011 09:01 PM
Fail to get work on linux CPU client? martin_metal_88 HardwareCanucks F@H Team 9 June 6, 2010 06:26 PM
Low Consumption Folder OR Part time POWER Folder ilya New Builds 3 May 16, 2010 03:33 PM
Attempt #10 to get work failed, and no other work to do. LaughingCrow HardwareCanucks F@H Team 3 May 5, 2010 08:29 AM
Folder down redwagon HardwareCanucks F@H Team 2 October 2, 2009 12:35 PM
