Old April 5, 2011, 07:39 AM
scruff's Avatar
When sizing airconditioning for electronics you have to figure out the wattage of the equipment and add in things like lighting , people , heat gain from windows etc. there is aprox. 3416 BTU per kw (if I remember correctly) so it should be fairly easy to figure out what you need and add a little for unknown heat gains . Measuring cooling loads in kw's is quite common in commercial HVAC . There is also lots of easy to use software for heat loss/gain calculations available .
Line Conditioners for voltage regulation DougTheSlug Power Supplies 18 November 27, 2009 02:39 PM
