-   HardwareCanucks F@H Team (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/)
-   -   Folding with a GTX560 (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/41996-folding-gtx560.html)
3.0charlie March 26, 2011 10:49 AM
Been so long since I have GPU folded... To those using a GTX560, what are your stable shader clocks at stock volts? My particular sample is at 1856 MHz at the moment (Core is at 928 MHz), and looks stable through 5 WUs.
This is the 560 I'm using: NCIX.com - Buy PNY GeForce GTX 560 Ti XLR8 Black Box 822MHZ 1GB GDDR5 Dual DVI Mini-HDMI DX11 PCI-E Video Card - PNY Technologies Inc - VCGGTX560TXPB - in Canada. Temps are dead stable at 59C, with 60% fan speed.
Thanks.
edit: should I use -advmethods, or not?
_dangtx_ March 26, 2011 05:13 PM
that is a healthy oc,sir!
cant answer your first q, but yes on advmethods.and forceasm :)
sswilson March 26, 2011 07:41 PM
1025 folding stable, but then again I'm throwing a fair amount of extra core voltage towards it. Temps max out at 65c, but that's an internal install with 100% fan.
Definitely yes on the -advmethods (sometimes hit over 20K PPD), but I'm not so sure about the forceasm.... what's it supposed to do?
Strangely enough, 1025 has been 24/7 folding stable since I got the card, but I've got to drop it down below 1K to play Civ IV.... go figure.
3.0charlie March 26, 2011 08:51 PM
I'm trying to stay with stock volts. I'll increase on step at a time then.
20k ppd? Which WUs? Because this card only folded P6801s since yesterday (when I started), and average is 14k ppd.
LCB001 March 26, 2011 09:35 PM
I can't get to the Fah-wiki right now but IIRC -forceasm is an old CPU client flag, the SMP client ignores it.
It should do nothing for a GPU client.
Man I've got to start playing Civ again, it's only been 3 years....
20k is probably on those super-fast units (p109xx and p112xx) that still pop-up every now and then, all they care about is Speed...
Wi-Fuzzy March 27, 2011 01:21 AM
2 Attachment(s)
I have 4 GTX 560 running in 1 box. The cards do get a little toasty, but the still overclock well. They have been running 24/7 for 2 weeks. BTW...they are MSi twin Frozr 880 factory cores. Fans at 90%. Don't laugh at the case...it's the only thing I had left. And...no I can't get anymore fans on them....there is also 1 duct taped to the back sucking air out.
Wi-Fuzzy March 27, 2011 01:27 AM
Yikes...I just looked at the post and saw the temps. The white fan inside the case had come unplugged. The max temp is now 73c.
ilya March 27, 2011 01:40 AM
You could probably get away with a few less fans if you actually did some cable management. Or cut the case up and used it as a work bench.
_dangtx_ March 27, 2011 05:23 AM
you sure it ignores it? hmm,i always put it in just in case it decides to lazy itself out
3.0charlie March 27, 2011 07:21 AM
Thanks all, I've bumped the shaders to 1900 MHz, still stock volts. I may raise the voltage, but I'll stop once the GPU reaches 65C, 65% fan speed.
