Old March 21, 2011, 02:54 PM
Look into Team Viewer too.. Its another free RDP client that I find works generally well.
Old March 21, 2011, 03:05 PM
lowfat's Avatar
Just use Logmein. It can't get easier than that. VNC is generally meant to be used in the same network. Using it over the internet takes a lot more time than Logmein.
Old March 21, 2011, 06:04 PM
+1 for logmein
QuadZilla & The Four Horsemen
Mining Bitcoins with: 7x6950, 3x5970, 7x5830, 2x5850
Old March 22, 2011, 07:16 AM
BrainEater's Avatar
I've looked into logmein.....
I assume that'll allow me to control folding ?
Intel 3930k /rIVe/32 Gb vengeance LP/3x eVGA 580's/Intel 520's/WD raptors/etc...
Old March 22, 2011, 08:43 AM
Yep, dont bother with the pro version, or once your trial for pro runs out just change the properties for the connections to use logmeinfree, pro has some nice stuff like file transfers between the controling client and serving client..... but worst case you can remotly upload to a hosting site then send yourself the link should you need something from the remote machine.
Old March 23, 2011, 05:26 PM
I found this thread while googling for something else. I didn't read all the replies but I had the same issue and here was my solution:
The driver unloads for RDP. You're not running the radeon driver so starting folding will fail. but folding can continue if it has already started. My solution?
I created a batch file that I use to disconnect from RDP instead of the regular disconnecting. What it does is first it disconnects, then is kills folding at home, then restarts it. It does a couple other things but they aren't related to your problem.
Old March 26, 2011, 03:26 PM
BrainEater's Avatar
I ended up going with Logmein pro2....trial at the moment but I might actually buy it.
Works really well.....I can fully control my main folding rig remotely.
Might have to shoot back to calgary before may and get my server on it too..
Lazy Remote Desktop Q & A The Quicken Networking 4 March 4, 2011 09:54 PM
Remote Desktop... ow to I get the thing working? Helix Networking 22 April 19, 2010 06:38 AM
Can't remote desktop to my Atom anymore. Dr_BenD_over Networking 2 October 17, 2009 02:12 PM
Windows 7 Remote Desktop muse108dc Networking 2 May 14, 2009 07:23 PM
remote desktop CTA Networking 13 November 20, 2008 01:40 PM
