Originally Posted by Zink An OC'd SR2 will draw right aroung 500W from the wall while each 2600K should draw a max of just over 200W if you use a low power GPU and run a high OC. The difference ends up being under 150W, not too bad. |
I would guess a system with low powered vid card somewhere in the 225-250W range when folding..
Most online sources show the CPU at 4.4Ghz at over 112W by itself (from the base 86W it draws at stock clocks) Factor in having older power supplies and such, and the fact most will try for 4.7+Ghz, it would bump the wattage somewhat.
I was a bit off by saying 350W, that's for sure.. I wasn't aware of the 1155's lower power consumption. I'll probably be getting a 2600k soon anyways, and i'll compare that versus my SR-2 w/ dual 5645's @ 3.7Ghz and post the results. I don't have a line regulator, but i'll be comparing them through the same outlet at the same point in time (for any variance with line voltage, which could skew power results)
And yeah, the factoring in air conditioning thing I learned this past summer.. when I ran a 12,000 BTU air conditioner 24/7 to cool the basement with all my folding rigs.
It would be nice to have utilities paid for, however you hit the nail on the head about environmental impact with the entire setup.
Anywho, in about 2 weeks i'll have some real numbers to throw at the power consumption issue - because it is a HUGE issue for me right now, and i'm looking to scale back with the most power/heat effective farm.
