<~----> No gain from Radeon 4870 + Core i5 2500k folding - Hardware Canucks
Old January 18, 2011, 04:09 PM
Default No gain from Radeon 4870 + Core i5 2500k folding
Hi all,
I'm folding with my primary PC (Core i5 2500k 3.8 GHz / 8GB / Radeon 4870 512MB), and I noticed that no matter what I do with the settings, having my GPU + CPU folding together can't improve over just the CPU folding SMP units.
My setup is as follows:
  • SMP3 Client folding with no advmethods or bigadv, with -smp 4
  • GPU client folding with its default parameters, using Catalyst 10.12 DLLs
  • Environment variables...
  • BROOK_YIELD 2
  • CAL_NO_FLUSH 1
  • CAL_PRE_FLUSH 1
  • FLUSH_INTERVAL 384
If my FLUSH_INTERVAL variable is set to 256 or higher, the GPU client eats ~5% of the CPU time (or 20% of 1 core). I get ~2600 PPD from the GPU but I lose 3000 PPD from the SMP.
If I set my FLUSH_INTERVAL variable to 32-48, the GPU client reportedly does not take any CPU time in Task Manager. GPU gives me ~1050 PPD as it's being starved, but SMP still loses around 1100 PPD.
In both cases, the GPU client takes up an extra 63W (according to my UPS), for a LOSS of total PPD. Does anyone else have an SMP + ATI combo that actually gets positive gain from the GPU?
...or should I stop GPU folding and suffer from the Radeon 4870's bad idle power consumption?
Thanks
Old January 18, 2011, 04:41 PM
Every ATI card I've owned sucked too many cpu cycles to be worth using... Combine that will the low PPD the cards puts out... it' a no win situation. I'd fold only on the cpu or get a non fermi nvidia card. Fermi cards suck quite a few cycles as well but not as bad as ATI cards.
Old January 18, 2011, 04:47 PM
Thanks; as I thought... :(
So the extra wattage is better spent on OCing the i5 further I assume? (given that I'm at 46 Celsius with CPU fan at 1400RPM and my top exhaust fans unplugged, there's headroom left )
Old January 18, 2011, 04:56 PM
Ya that's what I would do... O.C. it as far as she'll go and see how much more power it consumes... shouldn't be that much more. You should also see a hefty increase in PPD with the increased clock speed...
Intel Sandy Bridge Core i5-2500K & Core i7-2600K Processors Review Comment Thread SKYMTL CPU's and Motherboards 52 November 6, 2011 08:21 AM
Heatsink that is compatible with Radeon 4870 and Radeon 5850? lsquare Video Cards 7 March 28, 2010 07:04 AM
folding on 3 core / core free for gpu folding phil3_66666 HardwareCanucks F@H Team 12 January 11, 2010 06:07 PM
EVGA GTX 260 Core 216 55nm vs Palit Radeon HD 4870 512MB Butkick Video Cards 19 December 1, 2009 08:22 PM
