Old January 7, 2008, 08:28 PM
Cptn Vortex's Avatar
Default Setting Core Affinity
Quick question. I use two windows based console instances to Fold. I always set them up with one's affinity set to core 2, and the other to core 3. I have my computer's screensaver to come on every 10 minutes, as I leave the computer folding but don't want to leave a static image on my screen. But, for some reason, whenever I come home from work, when I wake the computer up from the screensaver, it looks as though the core affinity's have re-set, and both of the instances are showing their core priority to be shared over all 4 cores. Anyone have any ideas why this is?
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old January 7, 2008, 08:36 PM
have you create seperate shortcuts for all the instances and used the flags -aX where X is the core you want it to run on?
Old January 7, 2008, 08:39 PM
Yes I set up independent .exe's, in seperate folders, and it works great. But I have not tried those flags you speak of. Can you elaborate?
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old January 7, 2008, 08:54 PM
3.0charlie's Avatar
I sure hope enaberif knows where he's going, 'cause I have no idea how to resolve your problem!
Old January 7, 2008, 08:57 PM
Sorry had a brain fart!
This program will allow you to specify what .exe you want on what core and save that.
Try this:
Getting More Bang Out of Your Dual Processing Buck | Tom's Hardware
http://images.tomshardware.com/2004/...taskassign.zip
Old January 7, 2008, 09:21 PM
werty316's Avatar
Unless you are running the SMP client I wouldn't worry about setting the CPU affinity since the non-SMP console can only use one core per open console window anyways.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old January 7, 2008, 09:42 PM
Thats what he wants; 2 instances running on 2 different cores.
Setting Static IP in Vista 64 not being saved vintank Networking 4 July 15, 2008 11:37 AM
FS - Intel Core 2 Duo E6600 Dual Core Processor LGA775 Conroe 2.40GHZ 1066FSB 4MB L2 pat767 Buy/Sell & Trade 0 January 22, 2008 09:00 AM
Setting XFI Card and Ultra High Settings in BF2... Canadianguy Audio 10 December 4, 2007 09:12 PM
Need HELP setting up Media Center PC!!! SKYMTL HTPC Systems & Software 26 November 5, 2007 05:02 PM
Guide To Setting up file sharing in Windows XP Supergrover Networking 2 March 19, 2007 09:16 PM
