  #111 (permalink)
Old April 17, 2011, 04:04 PM
So both are at 1.25V? If so you should be able to go higher and get the same temps with the 2600k because of the reduced cores. Hitting over 4.5Ghz should be possible for true for apples to apples of optimal performance.
  #112 (permalink)
Old April 18, 2011, 04:47 AM
Originally Posted by Rison View Post
Both running Win7 home x64. Both using the latest windows client. Both systems running DDR3 @ 1600Mhz CL8 - the 980x has 6 gig, the 2600 has 8 gig (like it matters past 2 gig anyways) I wanted an apples to apples comparison.
Both are using CM V6GT coolers.. I run these boxes 24/7 folding, so I don't want to go crazy with the overclocks.
For the price difference between the 2 processors, I don't think you have to compare apples to apples, they are not in the same price range anyway. The better you can do in windows is with VMWare, 2600k can, 980x cannot (well yes it can but I will not be 100% cpu usage). I don't think there is any type of hype here about ppd numbers for 2600k...
  #113 (permalink)
Old April 18, 2011, 04:52 AM
Rison's Avatar
I'm not certain what vcore the 980x is. I would guess the 1.25-1.3v range. Both cpus run at around 62c, which is what i'm comfortable running them at 24/7.
To hit 4.6Ghz on the 2600k requires 1.28-1.3v (guess, didn't tweak much), it didn't like staying stable 4.6Ghz@1.25v. It put the temps up to 68c or something and increases the power draw to past 225W (from 170W).
There is also a point where adding more Mhz doesn't nessesarily mean more PPD, it can actually go down in some cases. I haven't actually tested the difference from 4.5 to 4.7+ on the 2600k but i'm sure it would increase up until 5.0Ghz or something.
i'll be installing the linuxrouter VM on my desktop for increased PPD for sure. Just gotta find the time. :)
I'll learn to manage my anger, when people learn to manage their stupid.
  #114 (permalink)
Old April 18, 2011, 04:59 AM
Rison's Avatar
Yeah, I agree that the 2600k is a "better bang for the buck" CPU choice in terms of pricing. It's also not like I went out and bought the 980x.. i've had two since last November. There isn't a lot of hype here on HWC, but there was a lot of bashing of the 980/990x when the 2600k came out, in form of reviews (once again, mostly other sites).
A lot of reviews had the 2600k at par, or beating the 980x at stock clocks and max overclocks. This isn't something I tested mind you, I tested "my real world 24/7 usage", which is more important than synthetic benchmarks on the bleeding edge of overclocking.
I'm actually thinking of buying another watercooling kit.. cooling them both, and clocking the bleeding snot out of them for something 'fun' to do..
DAMN YOU DAZMODE!!!! Making me look at your WEBSITE THE OTHER DAY!@#
lol..
  #115 (permalink)
Old April 18, 2011, 05:36 AM
My 2600k @ 5.0 (1.42VCore) with VMWare does 60k ppd too; power consumption (per APS's app) is 273W at full load.
5.0 !
Jealous. As soon as I get my SNB back on water I'll see if I can clock that high.
Curious if you could post all of your voltages?
heatware
  #116 (permalink)
Old April 18, 2011, 07:07 AM
3.0charlie's Avatar
I'll see to that tonight.
Hydro-Quebec is salivating...
  #117 (permalink)
Old April 19, 2011, 03:18 PM
3.0charlie's Avatar
Sorry if it took a while, but I waited for the WU to be completed, and perform some maintenance on the rig. Settings for 4.944GHz. P8P67, 2600k.
blck 103
turbo all cores
multi 48x
internal pll voltage enabled
epu saving mode disabled
ll calibration ultra-high
vrm freq manual
vrm fixed mode 350
phase control extreme
duty control extreme
cpu current 130%
cpu voltage offset mode
offset voltage + 0.040
dram voltage 1.65
everything else auto
  #118 (permalink)
Old April 21, 2011, 05:08 AM
Alpine's Avatar
theses are my TFP with my 2600k at 4.9 folding under Vmplayer.
I was hoping hitting 60k ppd with this OC and its look like not.
Project ID: 6901
Core: GRO-A5
Credit: 8955
Frames: 100
Path: 192.168.0.102fah
Number of Frames Observed: 20
Min. Time / Frame : 00:22:32 - 57 577,0 PPD
Avg. Time / Frame : 00:25:25 - 48 062,8 PPD
Cur. Time / Frame : 00:22:32 - 55 837,5 PPD
R3F. Time / Frame : 00:22:38 - 55 590,8 PPD
All Time / Frame : 00:22:49 - 55 144,1 PPD
Eff. Time / Frame : 00:29:19 - 42 917,7 PPD
Main system
|I7 3930K|Asus P9X79 WS|2X Evga GTX 690|Samsung 256G Pro|H100|Dominator Platinium 16GB 2133Mhz|AX1200|540 AIR|SP2500|Vengeance 2000|IBM PRO/1000 PT Quad Port|
  #119 (permalink)
Old April 21, 2011, 03:12 PM
Alpine's Avatar
... my boy push the reset button. NNNNNNNNNNOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOo o.
PC reboot, start VM, NNNNNNNNNOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO calisse , 40% job done lost.....................
Main system
  #120 (permalink)
Old April 21, 2011, 03:23 PM
Dead Things's Avatar
Hourly backups. C'mon Alpine, are you new?
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
Follow my benching, folding, mining and miscellaneous shenanigans @dt_oc
AND PPD WILL SUFFER , THUNDERED THE FOLDING GODS!! _dangtx_ HardwareCanucks F@H Team 39 February 21, 2010 11:51 AM
Folding on Fermi: 200K PPD???? chrisk HardwareCanucks F@H Team 30 October 14, 2009 04:43 PM
New Folding/Crunching Rig crazyhorsejohnny HardwareCanucks F@H Team 5 September 13, 2009 09:13 AM
Need Suggestions for Folding Rig redwagon HardwareCanucks F@H Team 27 September 3, 2009 12:28 AM
Motherboard for Folding Rig? ImmaPC CPU's and Motherboards 18 June 11, 2009 08:43 PM
