Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > HardwareCanucks [email protected] Team
Old January 3, 2011, 05:57 PM
Default Quiet folding
Hey guys,
I know it sounds like an oxymoron but I'm trying to get my rig to fold quietly. Now fan noise doesn't bug me, whats getting to me is coil whine. I've gone though about couple PSUs and Video cards trying to get a combination that doesn't whine.
I'm currently using two gtx 460s in SLI from MSI with solid chokes for no coil whine but every PSU I've tried SSCCRREEAAMMS while folding. My old PSU a corsair tx 650 would while so I got rid of that and got a xfx 850w (seasonic oem) and it screams too.
Does anybody have an idea on a setup that won't deafen me with high pitch noises?
Old January 3, 2011, 06:03 PM
you need to check juice from the wall, maybe plug it in a cheap (24$) line conditioner that may or may not already be included with your ups, if you have one.
and then,maybe focus on bigadv folding if the video cards are indeed the culprit of the wine.
i keep telling ppl to go with the hr-02 , very few do, even those that dont care about price tag and can accomodate its height in the case :)
check the passive numbers. munsta!
Old January 3, 2011, 06:04 PM
Too many random incompatibilities with the advanced C-states and quality PSUs, could try the new Antecs made by Delta though, haven't heard of compatibility issues there. (at least not yet)
Only surefire way would be to void your warranty, open up the unit and dab the coils with glue/resin.
Old January 3, 2011, 06:06 PM
chrisk's Avatar
Folding Captain
I use Enermax Revolution+85 1050w, and Corsait 850HX, and get no coil while at all. I do get a bit on a video card, but its not bad.
Fold for team #54196
Old January 3, 2011, 06:14 PM
gingerbee's Avatar
haven't had coil whine in years but i only use seasonic and corsair psu in my house now.
Old January 3, 2011, 06:15 PM
I'm running 20k PPD using i7 920 d0 @ 4ghz 1.25v with -advmethods. bigadv deadlines scare me as I don't always fold 24/7. And the coil whine only starts when I GPU fold, also the frequency of the squeal changes with the shader clock of my GPUs.
As for the cooling I already have a nh-d14 of my CPU :) keeps around 65c with 19c ambient.
I might try getting a line conditioner and seeing if it helps.
Old January 3, 2011, 06:22 PM
well, then gpu folding is the best bet.
may have to play around with them, i remember on older g80/92 parts i had to up or down it by some mhz in order to make it inaudible, or trade the cards and be done with it
sorry, youve got already a good cooler :p
Old January 3, 2011, 07:17 PM
I had the core clock related coil whine with my crappy ULTRA psu but with the a cheap Enermax Liberty 620W I bought on the BST forum there is very little whine.
Old January 3, 2011, 07:30 PM
chrisk's Avatar
Folding Captain
I would think that a better PSU would do it.
That being said, I use UPSes on both my rigs, which cleans the power too so I am not sure how much it helps. but I would say the PSUs I use are the biggest factor.
Old January 3, 2011, 08:42 PM
I got the best solution for the noise, house the rigs in a complex where all the residents share the power bill and my deaf Grandmother only complains of the heat they make :)
Have an A-1 day!
A quiet keyboard Prolab Peripherals 12 November 25, 2010 12:20 PM
Looking for QUIET 120mm fans Caldezar Air Cooling 20 July 20, 2010 01:32 PM
Low wattage, quiet PC. m0pelley99 New Builds 21 September 30, 2009 05:52 PM
quiet cooling needed Jim Air Cooling 13 January 30, 2009 01:32 PM
Cool and Quiet Hell Supergrover Troubleshooting 4 September 7, 2007 07:16 PM
