Originally Posted by ToXic How do I get each card doing a project though? |
You konw, I think if you check the FAQ's and setup guides here, all of this is previously documented...You should have a view, but to help you out regardless...
Create two folders, call one (for example) GPU0 and the other GPU1
Run the GPU0 systray client, set the machineID to (example) 1
Run the GPU1 systray client, set the machineID to (example) 2
Im not sure why the SMP client is only using one of your cores...Did you set any flags to it? I assume not...Probably going to have to wait for one of the other F@H gurus to come by for that question Toxic...sorry
