Old October 28, 2010, 07:39 AM
Default Low PPD for GPUs
So both my GTX460 and GTS450 are running a TPF of around 2 mins for a 925/911 WU which is normally a under a min TPF ... Afterburner says both cards are only running at under 50% load.
What could be the issue? Temps are fine.
Old October 28, 2010, 07:42 AM
hmmm...were these wu's going 100% on the cards before? complete wu info plz.
Old October 28, 2010, 07:54 AM
Any CPU intensive tasks you're running other than F@H?
When I was folding with my 8600GT in a P4 system, the GPU client wouldn't request 100% usage on new WUs when CPU resources were limited. But of course that's just a hunch based on different architecture and getting more info would probably be a better idea.
Old October 28, 2010, 07:58 AM
Yeah the 912/925 pointers were going 100% at first, than got a bunch of 611s of a couple days now I'm back with 912/925s and the card won't go over 50% core usage. Restored to stock, re-started my clients and computer, still stuck with the problem.
My 460 is working on P11252 (R1, C17, G35)
Old October 28, 2010, 08:00 AM
Nope, like I said nothing changed and it was working fine a day ago.
And it's happening on two different machines.
Old October 28, 2010, 08:29 AM
stoanee's Avatar
What are you using to manage the cards, ie. Evga precision, MSI afterburner, Prifinnity? I had to at one time use a program to force the cards to high performance 3D, I believe it was Rivatuner......
heatware
Old October 28, 2010, 08:42 AM
just in case, might want to furmark it but it should go 100%
Old October 28, 2010, 09:19 AM
Using Afterburner and I did Kombustor and Furmark and card goes to 100% no problem.
Old October 28, 2010, 11:09 AM
chrisk's Avatar
Folding Captain
My first thought was that something was eating up your CPU cycles (ie. running smp). But it seems you have ruled that out.
My second thought was a driver issue, but if your card goes into 3D mode and runs at 100% in furmark then I am going to assume that your drivers are fine.
So my third thought is that something is up with your core; stop the client, delete the core.exe files, work folder, and queue.dat files. Restart so that a fresh core and work folders are generated.
If it still continues, I would uninstall afterburner, kombustor, etc, and install fresh drivers with everything on stock.
Fold for team #54196
Old October 28, 2010, 12:00 PM
sswilson's Avatar
Try running realtemp. My initial GTS 450 wouldn't run 100%, but for some reason running realtemp in the background gives it the poke it needs to run full speed. Tried different drivers with no change, but it runs fine with realtemp up and running.
Low PPD for an i7... fjanicki HardwareCanucks F@H Team 16 October 13, 2010 09:38 AM
Should my PPD be this low? ilya HardwareCanucks F@H Team 3 May 4, 2010 06:57 PM
Low VMware ppd somecanadianguy HardwareCanucks F@H Team 8 September 24, 2009 02:01 PM
Low PPD on VMs Perineum HardwareCanucks F@H Team 11 August 30, 2009 05:19 PM
[FS] P5Q PRO + low ultra end AGP PCIE GPUS Silvgearx Buy/Sell & Trade 1 January 27, 2009 06:18 PM
