  #31 (permalink)
Old October 20, 2010, 03:32 PM
Originally Posted by sswilson View Post
Nope, same width as a traditional 2 slot plastic shrouded card. Grab one quick... it's already OC'd to 850, the cooler is phenomenal, and hopefully you'll have as much luck with overhead on the OC as I did!!!! :)
K thanks... Sucks that there is a limit of one per customer now if I could only find my credit card...
  #32 (permalink)
Old October 21, 2010, 07:54 AM
10e's Avatar
10e 10e is offline
I just got one of these, so I'll let ya know. The only issue I see is if the case doesn't have much clearance for a slightly "tall" card, as the heat sink does rise above the card's PCB by a little bit, but I doubt this would be an issue unless you have some sort of "VGA" cooler fan or 38mm side intake fan right over it.
Comment Thread for ALL Launch-Day GTS 450 Reviews SKYMTL Video Cards 83 September 23, 2010 06:13 AM
GTS 450 or HD 5770? technix Video Cards 11 September 15, 2010 06:37 PM
GTS 450 is out already? bvsbutthd101 Video Cards 49 September 12, 2010 02:29 PM
