Originally Posted by Zero82z No, it has nothing to do with failure.  |
hmm, youre saying its normal then?
[01:57:14] - Machine ID: 2
[01:57:14]
[01:57:14] Loaded queue successfully.
[01:57:14]
[01:57:14] + Processing work unit
[01:57:14] Core required: FahCore_11.exe
[01:57:14] Core found.
[01:57:14] Working on queue slot 06 [October 10 01:57:14 UTC]
[01:57:14] + Working ...
[01:57:15]
[01:57:15] *------------------------------*
[01:57:15] Folding@Home GPU Core
[01:57:15] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[01:57:15]
[01:57:15] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14
.00.50727.762 for 80x86
[01:57:15] Build host: amoeba
[01:57:15] Board Type: Nvidia
[01:57:15] Core :
[01:57:15] Preparing to commence simulation
[01:57:15] - Looking at optimizations...
[01:57:15] - Files status OK
[01:57:15] - Expanded 62816 -> 336076 (decompressed 535.0 percent)
[01:57:15] Called DecompressByteArray: compressed_data_size=62816 data_size=3360
76, decompressed_data_size=336076 diff=0
[01:57:15] - Digital signature verified
[01:57:15]
[01:57:15] Project: 10512 (Run 6, Clone 133, Gen 50)
[01:57:15]
[01:57:15] Assembly optimizations on if available.
[01:57:15] Entering M.D.
[01:57:21] Will resume from checkpoint file
[01:57:21] Tpr hash work/wudata_06.tpr: 3522014391 814738536 63427322 455622710
993492520
[01:57:21]
[01:57:21] Calling fah_main args: 14 usage=100
[01:57:21]
[01:57:21] Working on Protein
[01:57:22] Client config found, loading data.
[01:57:23] Starting GUI Server
[01:57:23] Resuming from checkpoint
[01:57:23] fcCheckPointResume: retreived and current tpr file hash:
[01:57:23] 0 3522014391 3522014391
[01:57:23] 1 814738536 814738536
[01:57:23] 2 63427322 63427322
[01:57:23] 3 455622710 455622710
[01:57:23] 4 993492520 993492520
[01:57:23] fcCheckPointResume: file hashes same.
[01:57:23] fcCheckPointResume: state restored.
[01:57:23] Verified work/wudata_06.log
[01:57:23] Verified work/wudata_06.edr
[01:57:23] Verified work/wudata_06.xtc
[01:57:23] Completed 99%
edit : its finished
[01:59:00] Completed 100%
[01:59:00] Successful run
[01:59:00] DynamicWrapper: Finished Work Unit: sleep=10000
[01:59:10] Reserved 108720 bytes for xtc file; Cosm status=0
[01:59:10] Allocated 108720 bytes for xtc file
[01:59:10] - Reading up to 108720 from "work/wudata_06.xtc": Read 108720
[01:59:10] Read 108720 bytes from xtc file; available packet space=786321744
[01:59:10] xtc file hash check passed.
[01:59:10] Reserved 21864 21864 786321744 bytes for arc file=<work/wudata_06.trr
> Cosm status=0
[01:59:10] Allocated 21864 bytes for arc file
[01:59:10] - Reading up to 21864 from "work/wudata_06.trr": Read 21864
[01:59:10] Read 21864 bytes from arc file; available packet space=786299880
[01:59:10] trr file hash check passed.
[01:59:10] Allocated 560 bytes for edr file
[01:59:10] Read bedfile
[01:59:10] edr file hash check passed.
[01:59:10] Allocated 33516 bytes for logfile
[01:59:10] Read logfile
[01:59:10] GuardedRun: success in DynamicWrapper
[01:59:10] GuardedRun: done
[01:59:10] Run: GuardedRun completed.
[01:59:15] + Opened results file
[01:59:15] - Writing 165172 bytes of core data to disk...
[01:59:15] Done: 164660 -> 139493 (compressed to 84.7 percent)
[01:59:15] ... Done.
[01:59:15] DeleteFrameFiles: successfully deleted file=work/wudata_06.ckp
[01:59:15] Shutting down core
[01:59:15]
[01:59:15] Folding@home Core Shutdown: FINISHED_UNIT
[01:59:19] CoreStatus = 64 (100)
[01:59:19] Sending work to server
[01:59:19] Project: 10512 (Run 6, Clone 133, Gen 50)
[01:59:19] + Attempting to send results [October 10 01:59:19 UTC]
[01:59:22] + Results successfully sent
[01:59:22] Thank you for your contribution to Folding@Home.
[01:59:22] + Number of Units Completed: 115
[01:59:26] - Preparing to get new work unit...
[01:59:26] + Attempting to get work packet
[01:59:26] - Connecting to assignment server
[01:59:27] - Successful: assigned to (171.67.108.11).
[01:59:27] + News From Folding@Home: Welcome to Folding@Home
[01:59:27] Loaded queue successfully.
[01:59:28] + Closed connections
[01:59:28]
[01:59:28] + Processing work unit
[01:59:28] Core required: FahCore_11.exe
[01:59:28] Core found.
[01:59:28] Working on queue slot 07 [October 10 01:59:28 UTC]
[01:59:28] + Working ...
[01:59:28]
[01:59:28] *------------------------------*
[01:59:28] Folding@Home GPU Core
[01:59:28] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[01:59:28]
[01:59:28] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14
[01:59:28] Build host: amoeba
[01:59:28] Board Type: Nvidia
[01:59:28] Core :
[01:59:28] Preparing to commence simulation
[01:59:28] - Looking at optimizations...
[01:59:28] DeleteFrameFiles: successfully deleted file=work/wudata_07.ckp
[01:59:28] - Created dyn
[01:59:28] - Files status OK
[01:59:28] - Expanded 45491 -> 251112 (decompressed 552.0 percent)
[01:59:28] Called DecompressByteArray: compressed_data_size=45491 data_size=2511
12, decompressed_data_size=251112 diff=0
[01:59:28] - Digital signature verified
[01:59:28]
[01:59:28] Project: 5769 (Run 0, Clone 222, Gen 816)
[01:59:28]
[01:59:28] Assembly optimizations on if available.
[01:59:28] Entering M.D.
[01:59:34] Tpr hash work/wudata_07.tpr: 1452608344 2842297654 3147619565 152200
8195 3150965941
[01:59:49]
[01:59:49] Calling fah_main args: 14 usage=100
[01:59:49]
[01:59:49] Working on Protein
[01:59:49] Client config found, loading data.
[01:59:49] Starting GUI Server
[02:00:28] Completed 1%
[02:01:22] Completed 2%
[02:02:15] Completed 3%
[02:03:07] Completed 4%
[02:04:02] Completed 5%
ill keep an eye on it. i know i had a few reboots due to the dam drivers. lets seee....
