Old October 3, 2010, 07:11 AM
Default Question about PPD output for CPU/GPU
Just wondering if these look correct for the following components:
GTX 480's: 15984ppd
Phenom II X4 955: 212.25ppd
I'm not too worried about the GTX 480's, but the processor seems awfully slow when working through SMP WU's. I've had my computer on for 8-hour periods for two days now, and it's only finished one. Does that sound about right?
Also, just a side question: how do you close the SMP client properly? I just click the x on the top, but it always boots up saying that it was closed improperly.
Thanks in advance.
Old October 3, 2010, 07:58 AM
jcmaz's Avatar
I don't know anything about the GTX480 but my Phenom 945 @ 3.3Ghz does 1% every 8 minutes or so...
8 min X 100% / 60 min = 13.333 hours... Sounds about right.
Is you 955 OC'd?
But i'm no Folding guru...
-Plato
Old October 3, 2010, 08:38 AM
hmmmm...you sure you have your flags correctly set up? it is a bit low.
Old October 3, 2010, 08:45 AM
Well, I put in the -smp flag and allowed for -advmethods in the config process. Oddly enough though, leaving it for about an hour caused it to jump up to 788.58 ppd. Does that sound correct, or is that still low?
Old October 3, 2010, 09:01 AM
its still a bit low. although some wis are tankers :)
Old October 3, 2010, 09:17 AM
chrisk's Avatar
Folding Captain
Are you using Fahmon or HFM to monitor PPD? I thought you would get higher with that chip. Also, is there an OC?
Fold for team #54196
Old October 3, 2010, 09:27 AM
I'm using Fahmon to monitor my stuff. It is OC'ed to 3.7ghz, so that puzzles me even more as to why PPD is so low. But now I'm wondering if PPD increases as time passes, as it just hit 842.97 ppd Is that how it's supposed to happen, or is there something I'm missing here? Does it also have something to do with me apparently closing the client improperly? Any help is greatly appreciated for this.
Old October 3, 2010, 10:04 AM
Use HFM.NET instead. Fahmon does not factor bonus points into PPD calculations, so the numbers you see will be artificially low. There is a newer version of Fahmon that has basic bonus support, but since the program is poorly supported right now I still recommend that you use HFM. chriskwarren wrote up a guide for configuring HFM which you can find here: How to set up HFM.NET and FahMon to monitor Folding@home progress. Now with videos.
Old October 3, 2010, 10:18 AM
Followed your advice Zero, and the difference is nothing short of incredible. The GTX 480's PPD values dropped slightly to 15369.2, but the CPU now shows that it's pumping out 2782.1 PPD
So now that that's all fixed, that just leaves the question as to how to exit the SMP client properly. I'm thinking that I should probably find it out before accidentally corrupting something, so any help on this matter would also be greatly appreciated.
Old October 3, 2010, 10:32 AM
Click the X button. That's how you quit.
New Folder here, CPU PPD question RLP06 HardwareCanucks F@H Team 7 May 16, 2010 07:00 AM
A GPU for 5k PPD MarkOne HardwareCanucks F@H Team 63 January 18, 2010 09:18 PM
Less Total PPD with GPU+SMP? Draex HardwareCanucks F@H Team 14 November 5, 2009 03:31 PM
Crazy GPU PPD, Crap CPU PPD, help please Taz HardwareCanucks F@H Team 5 July 31, 2009 05:37 PM
Noob question: Can i fold with 2 clients - CPU & GPU? Kayen HardwareCanucks F@H Team 8 October 10, 2008 08:40 PM
