Old October 2, 2010, 09:38 PM
Spikemaul's Avatar
Default Problems with my SMP Client
Hey guys, I got this problem with my SMP client that's really pissing me off. Whenever I start it I can't get it to stop unless i reset my computer, then once it's re-booted I can open the client but it won't start. Once the client is open my IE8 won't work and I have to re-boot the computer again. I've tried getting rid of the WU that it was working on and it downloaded a new one and the problem is still there. I've completely re-installed the SMP client and I followed the stickied guide to a T. What are your suggestions? Thanks in advance.
Old October 2, 2010, 10:13 PM
more info on your smp config,os,etc pretty please.
i would try to install it on another drive and or partition.
ive had issues with closing my clients, whereas they would need minutes to close, and looked frozen for a little while.
Old October 2, 2010, 10:20 PM
Post your log file please.
Old October 2, 2010, 10:39 PM
Spikemaul's Avatar
That would be the Log file in the FAH6.30-win32-SMP Folder correct?
Old October 2, 2010, 10:41 PM
Spikemaul's Avatar
# Windows CPU Console Edition #################################################
Folding@Home Client Version 6.30
Folding@home - Main
Launch directory: C:\Program Files (x86)\FAH6.30-win32-SMP
Executable: C:\Program Files (x86)\FAH6.30-win32-SMP\Folding@home-Win32-x86.exe
[02:22:14] Configuring Folding@Home...
[02:29:16] - Ask before connecting: No
[02:29:16] - User name: Spikemaul (Team 54196)
[02:29:16] - User ID: 1178443D225248C3
[02:29:16] - Machine ID: 1
[02:29:16]
[02:29:16] Work directory not found. Creating...
[02:29:16] Could not open work queue, generating new queue...
[02:29:16] - Preparing to get new work unit...
[02:29:16] Cleaning up work directory
[02:29:16] + Attempting to get work packet
[02:29:16] Passkey found
[02:29:16] - Connecting to assignment server
[02:29:16] - Successful: assigned to (171.64.65.62).
[02:29:16] + News From Folding@Home: Welcome to Folding@Home
[02:29:17] Loaded queue successfully.
[02:29:22] + Closed connections
[02:29:22]
[02:29:22] + Processing work unit
[02:29:22] Work type 78 not eligible for variable processors
[02:29:22] Core required: FahCore_78.exe
[02:29:22] Core not found.
[02:29:22] - Core is not present or corrupted.
[02:29:22] - Attempting to download new core...
[02:29:22] + Downloading new core: FahCore_78.exe
[02:29:24] + 10240 bytes downloaded
[02:29:24] + 20480 bytes downloaded
[02:29:24] + 30720 bytes downloaded
[02:29:24] + 40960 bytes downloaded
[02:29:24] + 51200 bytes downloaded
[02:29:24] + 61440 bytes downloaded
[02:29:24] + 71680 bytes downloaded
[02:29:24] + 81920 bytes downloaded
[02:29:24] + 92160 bytes downloaded
[02:29:24] + 102400 bytes downloaded
[02:29:24] + 112640 bytes downloaded
[02:29:24] + 122880 bytes downloaded
[02:29:24] + 133120 bytes downloaded
[02:29:24] + 143360 bytes downloaded
[02:29:24] + 153600 bytes downloaded
[02:29:24] + 163840 bytes downloaded
[02:29:24] + 174080 bytes downloaded
[02:29:24] + 184320 bytes downloaded
[02:29:24] + 194560 bytes downloaded
[02:29:24] + 204800 bytes downloaded
[02:29:24] + 215040 bytes downloaded
[02:29:24] + 225280 bytes downloaded
[02:29:24] + 235520 bytes downloaded
[02:29:24] + 245760 bytes downloaded
[02:29:24] + 256000 bytes downloaded
[02:29:24] + 266240 bytes downloaded
[02:29:24] + 276480 bytes downloaded
[02:29:24] + 286720 bytes downloaded
[02:29:24] + 296960 bytes downloaded
[02:29:24] + 307200 bytes downloaded
[02:29:24] + 317440 bytes downloaded
[02:29:24] + 327680 bytes downloaded
[02:29:24] + 337920 bytes downloaded
[02:29:24] + 348160 bytes downloaded
[02:29:24] + 358400 bytes downloaded
[02:29:24] + 368640 bytes downloaded
[02:29:24] + 378880 bytes downloaded
[02:29:24] + 389120 bytes downloaded
[02:29:24] + 399360 bytes downloaded
[02:29:24] + 409600 bytes downloaded
[02:29:24] + 419840 bytes downloaded
[02:29:24] + 430080 bytes downloaded
[02:29:24] + 440320 bytes downloaded
[02:29:24] + 450560 bytes downloaded
[02:29:24] + 460800 bytes downloaded
[02:29:24] + 471040 bytes downloaded
[02:29:24] + 481280 bytes downloaded
[02:29:24] + 491520 bytes downloaded
[02:29:24] + 501760 bytes downloaded
[02:29:24] + 512000 bytes downloaded
[02:29:24] + 522240 bytes downloaded
[02:29:24] + 532480 bytes downloaded
[02:29:24] + 542720 bytes downloaded
[02:29:24] + 552960 bytes downloaded
[02:29:24] + 563200 bytes downloaded
[02:29:24] + 573440 bytes downloaded
[02:29:24] + 583680 bytes downloaded
[02:29:24] + 593920 bytes downloaded
[02:29:24] + 604160 bytes downloaded
[02:29:24] + 614400 bytes downloaded
[02:29:24] + 624640 bytes downloaded
[02:29:24] + 634880 bytes downloaded
[02:29:24] + 645120 bytes downloaded
[02:29:24] + 655360 bytes downloaded
[02:29:24] + 665600 bytes downloaded
[02:29:24] + 675840 bytes downloaded
[02:29:24] + 686080 bytes downloaded
[02:29:24] + 696320 bytes downloaded
[02:29:24] + 706560 bytes downloaded
[02:29:24] + 716800 bytes downloaded
[02:29:24] + 727040 bytes downloaded
[02:29:24] + 737280 bytes downloaded
[02:29:24] + 747520 bytes downloaded
[02:29:24] + 757760 bytes downloaded
[02:29:24] + 768000 bytes downloaded
[02:29:24] + 778240 bytes downloaded
[02:29:24] + 788480 bytes downloaded
[02:29:24] + 798720 bytes downloaded
[02:29:24] + 808960 bytes downloaded
[02:29:24] + 819200 bytes downloaded
[02:29:24] + 825633 bytes downloaded
[02:29:24] Verifying core Core_78.fah...
[02:29:24] Signature is VALID
[02:29:24]
[02:29:24] Trying to unzip core FahCore_78.exe
[02:29:25] Decompressed FahCore_78.exe (2338816 bytes) successfully
[02:29:30] + Core successfully engaged
[02:29:35]
[02:29:35] + Processing work unit
[02:29:35] Work type 78 not eligible for variable processors
[02:29:35] Core required: FahCore_78.exe
[02:29:35] Core found.
[02:29:35] Working on queue slot 01 [October 3 02:29:35 UTC]
[02:29:35] + Working ...
[02:29:37]
[02:29:37] *------------------------------*
[02:29:37] Folding@Home Gromacs Core
[02:29:37] Version 1.90 (March 8, 2006)
[02:29:37]
[02:29:37] Preparing to commence simulation
[02:29:37] - Looking at optimizations...
[02:29:37] - Created dyn
[02:29:37] - Files status OK
[02:29:37] - Expanded 747057 -> 3748137 (decompressed 501.7 percent)
[02:29:37] - Starting from initial work packet
[02:29:37]
[02:29:37] Project: 6511 (Run 14, Clone 29, Gen 43)
[02:29:37]
[02:29:37] Assembly optimizations on if available.
[02:29:37] Entering M.D.
[02:29:43] Protein: UBIQUITIN MODEL3750 in water
[02:29:43]
[02:29:43] Writing local files
[02:29:44] Extra SSE boost OK.
[02:29:44] Writing local files
[02:29:44] Completed 0 out of 250000 steps (0%)
Folding@Home Client Shutdown.
Old October 2, 2010, 10:50 PM
That is not an SMP unit. Your client is not set up correctly.
Old October 2, 2010, 10:58 PM
Spikemaul's Avatar
This is exactly the way it was set up for months with no problems.
Old October 2, 2010, 11:01 PM
Regardless, it is wrong. You need to use the -smp flag in order to receive SMP work.
Old October 2, 2010, 11:04 PM
Spikemaul's Avatar
I added that flag when i configured it.
Old October 3, 2010, 12:20 AM
just for asking the question, your system is still 100% stable no errors or anything in prime etc right? no memory errors?
The official SMP client help thread: Post your problems here! Zero82z HardwareCanucks F@H Team 36 May 10, 2010 03:45 PM
Problems with SMP Client Spikemaul HardwareCanucks F@H Team 7 January 29, 2010 09:43 PM
SMP client help phil3_66666 HardwareCanucks F@H Team 17 April 24, 2009 09:34 PM
Need help setting up SMP client Alwaysrun HardwareCanucks F@H Team 7 February 8, 2009 07:47 PM
SMP client errored BrainEater HardwareCanucks F@H Team 8 October 9, 2008 05:50 PM
