Old August 27, 2010, 09:38 PM
homer98's Avatar
Default Help with CPU client
Hey all, just got set up with CPU and GPU folding, downloaded and configured HFM.NET, showing the GPU results fine. but my CPU client is not doing anything even though the cores are all active?
says RunningNoFrameTimes highlighted in yellow, where as the GPU says running in green, what does that mean, why is the CPU doing something but not? Help. Thanks
Old August 27, 2010, 09:47 PM
you have to digg it up in app data, if memory serves right.
btw which client? smp?
Old August 27, 2010, 09:52 PM
homer98's Avatar
SMP with the -bigadv flag as well. I closed the client, then reopened it, then stated from last check point had 1500 points out of 250000. So it is working, but why isnt it showing properly on HFM.NET?
Old August 27, 2010, 09:56 PM
SugarJ's Avatar
If I recall correctly, HFM won't show it as working until it has completed 1%, or in this case 2500/250000.
EDIT: keep in mind the monitoring programs only check the log files, and don't talk directly to the folding clients.
Old August 27, 2010, 09:58 PM
homer98's Avatar
Ahh, gotcha, updates every 1% I assume, thats probably why it wasnt showing anything on the cpu client itself.
So these SMP folds take a really long time??
Old August 27, 2010, 10:03 PM
depending on the wu, and cpu used, yes it can take longer. ppd is great, but if something happens inbetween you can lose the whole thing. for people who dont keep the machines 24/7 regular clients seems to be the way
Old August 27, 2010, 10:05 PM
homer98's Avatar
ok, I think I might switch to regular SMP client, I dont need to put how many cores or anything right? It seems to put the load on all 8 of them by default, so I dont need to change anything then, correct?
Old August 27, 2010, 10:06 PM
SugarJ's Avatar
I haven't done SMP folding in a few months, but yes, they generally take a lot longer than the GPU units. IIRC, my 920 took up to 18 hours for SMP units, and 3+ days for BIGADV units, while my GPU units are generally completed in under an hour.
EDIT: as long as you use the -smp flag, I think it defaults to using all cores unless you use a number argument like -smp 6
Old August 27, 2010, 10:08 PM
homer98's Avatar
mmk, How do I switch from -bigadv units to regular units, I took the flag off the shortcut to just SMP. but it is still folding the bigadv unit, how do I drop it and start folding regular SMP?
Old August 27, 2010, 10:16 PM
SugarJ's Avatar
Stop the client, delete the current WU from your work directory, restart the client with new flags.
I normally wouldn't advocate that, but since you JUST started the bigadv unit, not much work will be lost.
Fail to get work on linux CPU client? martin_metal_88 HardwareCanucks F@H Team 9 June 6, 2010 06:26 PM
Installing cpu client on two hundred E8400's. 0o0 HardwareCanucks F@H Team 24 June 5, 2010 09:01 AM
CPU usage with GPU client paused... somecanadianguy HardwareCanucks F@H Team 0 July 22, 2009 02:24 PM
CPU client not working Mecher HardwareCanucks F@H Team 9 March 31, 2009 12:32 PM
CPU Client BT! HardwareCanucks F@H Team 1 February 12, 2009 10:33 PM
