Old August 27, 2010, 10:44 PM
homer98's Avatar
Alright, I will keep that in mind from now on, changed it up now its all good, whats the approximate PPD I should expect with standard SMP client? 8 cores? CPU is running at 3Ghz?
Old August 27, 2010, 11:33 PM
lowfat's Avatar
I am going to take a guess and say around 8-9k.
Mael
Big Lian Li
Forever Alone
Old August 28, 2010, 08:31 AM
With normal SMP you should be seeing about 8-12k PPD depending on the unit. It's good that you stopped folding -bigadv because an i7 running at 3GHz is not fast enough to complete -bigadv units within the preferred deadline. However, if you are ever interested in overclocking your CPU to around 4GHz, then -bigadv would be the way to go since it provides substantial PPD improvements over normal SMP.
Old August 28, 2010, 09:35 AM
So true!
An i7 overclock no problem to minimum 3,8 ghz, and at 3,8 ghz it give me 30 000 ppd on the newer bigadv unit. (2685, 2686, 2692)
Old August 28, 2010, 10:11 AM
homer98's Avatar
Yeah, I will look into that for sure, but I still need to get a CPU cooler before overclocking. Right now im trying to manage with stock cooler, so there is tons of room for improvement. I also havent really overclocked before, other than my vid card. so still a bit new to that area. I have heard lots of good things about the Noctua D14, is it worth the $90 ? NCIX has the U12 cooler on sale right now for $50. what should I go for?
Old August 28, 2010, 10:34 AM
chrisk's Avatar
Folding Captain
I ran a i7 920 at 3.6 on a $30 Coolermaster Hyper 212+. YMMV.
You have just started folding as well, so you should try to get a dozen or so SMP units done successfully beofre attempting bigadv.
Did you get yourself a passkey?
Fold for team #54196
Old August 28, 2010, 10:39 AM
homer98's Avatar
Yup, got a passkey and entered it. good to go, everything is running fine, got HFM.NET working too. all's good. Would like to get atleast a decent HSF so I can do some overclocking, might check out the new NCIX store in Markham and see what I can get there.
Old August 28, 2010, 10:44 AM
chrisk's Avatar
Folding Captain
You need to complete 10 regular smp units in order to qualify for the bigadv bonus. 80% of the smp units you do need to be successful. If you already killed a bigadv unit, that would count as one against you.
Just let the regular smp units fold for a while before attempting bigadv. Give it about a week, depending on how much you let it fold.
Make sure you request a folding tag (check the stickies above) and welcome to the team!
Chris
  #19 (permalink)
Old August 28, 2010, 10:51 AM
geokilla's Avatar
When I left which was 12pm, there was still a long line up there. I'd estimate a 3 hour wait. Good luck!
Fail to get work on linux CPU client? martin_metal_88 HardwareCanucks F@H Team 9 June 6, 2010 06:26 PM
Installing cpu client on two hundred E8400's. 0o0 HardwareCanucks F@H Team 24 June 5, 2010 09:01 AM
CPU usage with GPU client paused... somecanadianguy HardwareCanucks F@H Team 0 July 22, 2009 02:24 PM
CPU client not working Mecher HardwareCanucks F@H Team 9 March 31, 2009 12:32 PM
CPU Client BT! HardwareCanucks F@H Team 1 February 12, 2009 10:33 PM
