Old May 26, 2010, 09:52 PM
geokilla's Avatar
Default Sudden Surge of EUE. Caused by Heat?
Can extreme heat cause EUEs? My sister's Athlon X2 @ 2.65Ghz has run into at least 5 to 10 EUEs with the recent heatwave. According to HWMonitor, CPU temps are at 70C under F@H. I'd hate to see what it's at when I stress test using OCCT.
Old May 26, 2010, 10:03 PM
I don't think it's likely that the processor temperature is causing the EUEs, but it could be that some other component in the system (RAM, chipset, etc.) isn't responding well to the heat and is causing the EUEs to occur.
Old May 27, 2010, 02:46 PM
geokilla's Avatar
Great... Nothing I can do then I guess...
Old May 27, 2010, 02:50 PM
Arinoth's Avatar
Buy/run an air conditioner, i bet its one of the bridges. Try running a fan pointed towards the pc with the case open, that may help as well
Here I am: here I remain
Old May 27, 2010, 05:02 PM
geokilla's Avatar
AC is on, it's just that my sister's room and computer is very warm. Top floor + computer + all lights on cus no sunlight enters = heat! That and the computer is always warmer than all the other computers we have for some reason.
Old May 29, 2010, 07:04 AM
Well you can always try undervolting or underclocking - I know I can drop my CPU temp by ~4 degrees by undervolting the CPU. (although I heard some CPUs get less efficient and take up more power at a certain point)
That should at least reduce the heat floating around in the case.
I know it's not ideal but as a last resort there's throttling F@H using that CPU usage option to tell it to use less than 100% CPU.
*sudden video problems ? READ THIS* BrainEater Troubleshooting 16 December 28, 2009 01:23 PM
EUE's punk_zappa HardwareCanucks F@H Team 13 May 18, 2009 07:33 AM
DVD sudden disappear help pp1111 Troubleshooting 7 April 28, 2009 12:14 PM
Surge protector Kilauea Power Supplies 17 August 21, 2008 08:05 AM
Surge Protector Jon_di2 Off Topic 17 August 15, 2008 07:51 PM
