Old May 24, 2010, 05:18 PM
Default for those with x6's
hows power consumption while oc'ed? they dont have figures for lower clocks. trying to dig numbers for i7 860 overclock power figures...hmmmmmmmmmmmmmmmmmmmmmm
was looking at tpu's numbers
techPowerUp :: AMD Phenom II X6 1090T 3.20 GHz Review :: Page 12 / 13
Old May 24, 2010, 08:26 PM
Digikid's Avatar
Ouch! NOT good at all!!!!!!!
Old May 24, 2010, 08:37 PM
i was expecting 6 cores to ramp up, but unless thats a typo or something, its....baad....
someone find what a i7 highly clocked eats wattage wise
Old May 24, 2010, 09:09 PM
jcmaz's Avatar
But you gain approximately 10% in performance
-Plato
Old May 24, 2010, 09:25 PM
geokilla's Avatar
That doesn't seem right. Load power consumption between a stock and overclocked Thuban can't be more than double...
Old May 24, 2010, 09:44 PM
It absolutely can be double.
Old May 24, 2010, 09:46 PM
CMetaphor's Avatar
Quadfather
How can adding not even 50% voltage (for example) yield double the power consumption? or are you just talking yet again, lol.
Old May 24, 2010, 09:57 PM
I just calculated the theoretical power consumption increase factor for the overclock used in the article, and it came out to about 1.77. 440W divided by 228W is about 1.93. So it's pretty close, and certainly possible. Remember that power consumption increases linearly with an increase in frequency but with the square of the increase in voltage.
Old May 24, 2010, 10:58 PM
im telling you guys, wait for the 95 watter versions. 30 watts at stock might not seem that much, but a good 70-100 full oc may make quite the difference :)
imagine someoen trying to clock that mother on a 3 and a half blind phase mobo lol
*someone post the terminator kaboom piccie plz
Old May 25, 2010, 06:50 AM
CMetaphor's Avatar
Quadfather
But with increased voltage the efficiency goes down and more is lost to heat.... Still doesn't make any sense. The more you OC, the more heat your chip will produce meaning that more of the power you put into it is being lost to heat, rather than to consumption...
I'll check some numbers with my X6 and get back to this...
