<~----> for those with x6's - Page 4 - Hardware Canucks
  #31 (permalink)
Old May 27, 2010, 02:46 PM
geokilla's Avatar
Originally Posted by sswilson View Post
I can speak to this as I've run into it myself. The only monitoring software that appears to be giving reasonably believable temps on the Crosshair IV is the actual ASUS branded software. All other software (including the AMD overdrive software) appears to be reporting around 12c low.
How do you know it's 12C lower? Couldn't the ASUS program be 12C higher?
Have you guys tried using HWMonitor to track temps?
  #32 (permalink)
Old May 27, 2010, 02:54 PM
sswilson's Avatar
Because the coretemp reported temps simply aren't believable. As it stands, my 100% SMP2 load temps are reported as 47c in the ROG software and 34c in coretemp (same as the AMD software) at aprox 22c ambient. There's no way that my full load OC'd processor is only running 12c over ambient temps.
  #33 (permalink)
Old May 27, 2010, 04:43 PM
Originally Posted by SKYMTL View Post
Heat is the BYPRODUCT of increased power consumption. Basically, as efficiency goes down, power consumption AND heat production increase.
The correct way of phrasing that would be that as power consumption increases, heat also increases, and the increase in heat leads to a reduction in efficiency, which itself leads to more power consumption and more heat production.
  #34 (permalink)
Old May 27, 2010, 04:59 PM
geokilla's Avatar
You can't use Tjunction sensors with AMD CPUs. I've seen it in their CPU documentation before for the Athlon series. They only go by Tcase temps. I've said it many times but people just ignore me or think I'm crazy. Heck I even provide the documentation for it and sometimes they still think I'm crazy.
Now this might've all changed with the newer CPUs, but if the Tjunction sensors are still giving out those kinds of values, then I'm going to guess that they're defective as well.
  #35 (permalink)
Old May 27, 2010, 05:29 PM
sswilson's Avatar
Supposedly (from the ASUS website) asus is using a new method of reporting temps which is "fixed" in the lastest version of AMD overclocking software. I haven't had a chance to check the new version out yet so can only go by what tools I currently have. Every tool other than the ROG software reports temps much lower than what can be believed so I'm sticking with the ROG software for now.
  #36 (permalink)
Old May 27, 2010, 05:50 PM
that..or go directly inbetween the cooler and cpu and see what reading you get there. too much work, but could be fun to see what actual temps are recorded.
im telling all that dont need a hexa core on the spot to wait for 95 watters but i see none except oem's
  #37 (permalink)
Old May 27, 2010, 07:42 PM
sswilson's Avatar
IIRC there was a report/rumour about the other chips which stated that they won't be hitting retail channels at all.
  #38 (permalink)
Old May 28, 2010, 04:23 AM
thats what worries me. dont want to pick up a dell, drop a 125 watter in, snatch the 95 watter out. too much trouble lol
  #39 (permalink)
Old May 28, 2010, 08:31 AM
sswilson's Avatar
Hehehe....... You'd have to be careful with that. If the lower TDP chips are only available in OEM machines, there's a good possibility that retail motherboard bios' won't include them. That said.... I've looked into that kind of thing myself in the past for new builds.... If you can get it cheap enough, an OEM tower might be worthwhile for the CPU/HDD/ODD/MEM and then toss the rest of the crap. It's a pity the OS license ins't "Legally" transferable, but c'est la vie.......
  #40 (permalink)
Old May 28, 2010, 08:46 AM
yessir. bought dells for cpus only. 100 bucks cheaper in the end
