Old May 12, 2010, 05:47 AM
Dadi_oh's Avatar
Originally Posted by LCB001 View Post
I don't know much about ATi Folding, but have you changed the .dll's as 10e suggested in another post;
I don't see those files in my folding folder? I will have to do a search to see if they are stored elsewhere.
The thing is, the 5870 was folding fine before I added the GT240.
Rig1: Q9550 @3.8GHz Vendetta 2, P5Q-PRO, 6GB OCZ Reaper PC2-8500. 5870 1GB, GT240 Physx, Ultra LSP 750W, 2TB internal + 2TB external, 3X23" 5760X1080 eyefinity + GT240 Physx, HAF22 case 3X200mm : Win7 Pro
Rig2: E8200 @3.6GHz Vendetta HSF, DFI P45 LP-JR, 4GB 900MHz, 4870 512MB, X203W 20", Ultra Gladiator Case
Rig3: Q6600@ 3.5GHz H50, P5Q-PRO, 8GB, 8800GTS512, OCZ GameXStream 850W, Samsung 245BW 24" + 19" dual: Snow Leopard + Parallels Win7
Rig4: MAC mini Snow Leopard
Laptop: Macbook Pro 15"
Old May 12, 2010, 05:50 AM
10e's Avatar
10e 10e is offline
Dadi_oh,
Try the following to isolate which card is which. Don't worry about what GPU-Z says, as it may sort things in the list as it sees fit.
Assuming you have the ATI card in slot 1 as your main card in the box connected to the monitor, and (I'm assuming) you've removed or renamed the folding client's AMD/ATICALxx.dll files from BOTH clients, go ahead and remove the queue.dat file, work directory and fah_Corexx.exe files.
If the work/core files are there it may try processing a pre-existing work unit that is not valid (ie. an nVidia work unit if it's the ATI card or vice versa) for that particular client.
Start ONLY the first client with -gpu 0 -verbosity 9 flags. Take a look at the log file and check out which core it's using (either ATI or nVidia) it should download the correct one. The auto-detection algorithms should figure this out for ya.
This will tell you which card (ATI or nVidia) is card #1 or -gpu 0. Make sure you aren't getting UNSTABLE_MACHINE errors with that one.
If this works, then you can set the -gpu 1 (second folding) client to the opposite architecture either with the -forcegpu nvidia_g80 flag or -forcegpu ati_r700 flag.
Even in Vista/Win7 the nVidia card can work with the -forcegpu flag. I don't think the ATI card will work unless a monitor/dummy plug or KVM is connected to it.
Hope that helps.
Dadi_oh's Avatar
Originally Posted by Inik View Post
I tried with the same combination, but I gave up. The GT 240 is folding at Zero's house :)
I fold with the 5870 + Q6600
Doh!
(loads shotgun... shoots right foot... reloads shotgun... shoots left foot... aargh.
I could remove the GT240 until after the chimp challenge and reinstall later I guess. Hopefully I haven't buggered my 5870 folding so that even if I remove the GT240 it still isn't working....
Old May 12, 2010, 05:54 AM
Dadi_oh's Avatar
Originally Posted by 10e View Post
Dadi_oh,
Hope that helps.
Thanks. Will try this tonight.
I did dlete the work folders from both but did not delete the fahcore files. Maybe that is the issue.
The GT240 has a dummy plug. My 5870 has 3 monitors hanging off it (eyefinity).
Old May 12, 2010, 06:16 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
AH, that might be your issue. If you are using Win 7, unplug two monitors from the HD 5870, unplug the dummy plug from the GT 240 and try the suggestions listed above.
Old May 12, 2010, 06:20 AM
Dadi_oh's Avatar
I thought that the dummy plug was required on the GT240 or else the Nvidia drivers disable it? Or are you suggesting keep 1 monitor on the 5870 and 1 monitor on the GT240?
The thing is, the 5870 was folding fine before I added the GT240 and the 5870 had the 3 monitors attached to it.
Old May 12, 2010, 06:39 AM
SKYMTL's Avatar
Yeah, you are right. I forgot the new NV drivers will disable the card.
Old May 12, 2010, 01:06 PM
I haven't seen it mentioned in the thread so far, but did you run the mod from Hybrid PhysX mod v1.03
I know that's needed to get hardware physx enabled anyway. Not sure if it would affect folding the same way or not.
  #19 (permalink)
Old May 12, 2010, 01:30 PM
Dadi_oh's Avatar
Yes, that is the patch I used to get Physx running. In typical Nvidia style they disable Physx if they detect an ATI card in the system Fortunately, common sense prevails and there are workarounds.
Going to play some more tonight to see if I can get the folding working. Otherwise I may reinstall my UT3 and Mirrors Edge games to try out the Physx.
Building a dual GPU folding machine with one 16x and one 4x slot Photograph HardwareCanucks F@H Team 12 March 28, 2010 12:28 AM
ATI + Nvidia Physx Folding question nakano2k1 Video Cards 2 February 4, 2010 05:11 PM
Is this possible: nvidia and ATI gpu simultaneously Navi CPU's and Motherboards 20 January 24, 2010 05:19 PM
Nvidia + ati on same machine? martin_metal_88 Video Cards 10 August 24, 2009 08:27 PM
New Members Folding with Nvidia/Ati Gpu 2 Client/ Some Tips Dashock HardwareCanucks F@H Team 43 January 4, 2009 03:39 PM
