Old May 4, 2010, 05:37 PM
Default Should my PPD be this low?
I know I should be running the SMP client on at least 2 VM's, but the PPD on my Q6600 is just ridiculous. It's clocked at 3.0ghz atm.
Old May 4, 2010, 05:50 PM
Sushi Warrior's Avatar
I'm in a rather similar situation, only 800PPD on an E6850.
geokilla's Avatar
That's way to low. Remove the old client and follow the sticky here. If you're a new folder, make sure you have a passkey setup to your own name. However since you're folding for the Chimp Challenge, don't forget to get the passkey from the captains! I think the passkey was posted on a thread by chriskwarren as well.
http://www.hardwarecanucks.com/forum...-pictures.html
Old May 4, 2010, 06:57 PM
LCB001's Avatar
Folding Captain
Your screenshot shows your Q6600 as running the Classic (Uniprocessor) client not SMP2. If you check your task manager it should show only one core being stressed.
If you are running it under windows you don't need the VM's any more, just one SMP2 install is best...
Folding For Team 54196
My ppd low? gtx260 ubernoobie HardwareCanucks F@H Team 15 May 3, 2010 06:58 PM
Low VMware ppd somecanadianguy HardwareCanucks F@H Team 8 September 24, 2009 02:01 PM
Low PPD on VMs Perineum HardwareCanucks F@H Team 11 August 30, 2009 05:19 PM
Crazy GPU PPD, Crap CPU PPD, help please Taz HardwareCanucks F@H Team 5 July 31, 2009 05:37 PM
Scythe Shuriken Low Low-Profile CPU Cooler Hardware Canucks Air Cooling 0 April 30, 2008 09:24 AM
