This issue is here because I believe it is folding related.
These things started happening after I switched my main rig video cards up to the current config of Nvidia 285 (Primary monitor , pci-e 1) + Nvidia260 (secondary monitor , pci-e 2).I fold 24/7 with these 2 cards and the MPICH smp client...I also game using the secondary (260) for physX.
The machine runs factory settings , no OC.I can post exact machine specs etc if it'll help....It's the rig in my sig.
Before I start it's important to state that my machine runs perfectly.Every application I run works.There are no errors on anything I have tried.
The first symptom :
One of my harddrives started '
clicking' after several days of folding.The psu works fine......I then saw some thing about 'Thermal issues
At 100% load on everything , the cpu runs at 52c , the video cards are all below 65c , the HDD's are below 30C.....There is no heat issue that I can find.
This is all moot , because I cannot reproduce it , it hasnt done it in the last 2 weeks of testing.All the HDD's appear to be fine , and the clicking has not happened again.Everything works perfectly.
The second symptom So I took the machine out and cleaned it with compressed n2 yesterday . Once again , after a complete teardown/cleaning , it had issues.At this point the BIOS resets every time I reboot.I have checked every wire and connection , it all checks out. ....And once again , all apps/all drives work perfectly....but.. Symptom 3
For whatever reason , I had some 'hard reset' of IE . I got errors when coming here and a couple other places.....Thats gone away too though.
I'm at a loss.
My rig runs fine once it goes , but there's some sort of issue.I'm not going to do a teardown/analysis til after CC , but something is weird.
Thoughts ?
