Old April 17, 2010, 11:02 AM
Apollo4g's Avatar
Default Using less CPU with ATI cards?
Hey all i found this thread on OCN that changes some registry files to use less CPU usage with ATI cards.
The 2 files are on the link but here is what it says:
Any input? good idea/bad idea?
I made a .reg file that will add the 4 variables and another to remove them. Can use them to add the variables before you start folding, then use the Delete one to remove them when gaming. This is of course if you are even having problems like I did with gaming. If not, at least the add variables .reg can be used for those that want an easy route to doing it. Hope they help.
Here are the variables values they change, you can always edit the .reg file yourself to change the Flush Interval to experiment if needed(be sure to save as "unicode" and not ANSI if you do change them). The 2 .Reg files are attached in .rar format below. Only tested these on Windows 7 x86, I don't think they are any different for XP/Vista or x64.
GpuAddVars.reg:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Session Manager\Environment]
"Flush_Interval"="128"
"Brook_Yield"="2"
"Cal_No_Flush"="1"
"CAL_PRE_FLUSH"="1"
GpuDeleteVars.reg
"Flush_Interval"=-
"Brook_Yield"=-
"Cal_No_Flush"=-
"CAL_PRE_FLUSH"=-
Overclock.net - Overclocking.net - View Single Post - Some 4870x2 folding questions
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Old April 17, 2010, 11:08 AM
Sushi Warrior's Avatar
I have a big feeling that will screw something up. There's no free lunch....
Old April 17, 2010, 11:12 AM
chrisk's Avatar
Folding Captain
I have heard of the reg hack for ATI cards; I think sswilson folds with ATI cards he may be able to shed some light.
The foldingforum folks have tried them on different cards with only praise.
Fold for team #54196
Old April 17, 2010, 11:13 AM
Arinoth's Avatar
If you have an i7 1366 system why would you be worrying about an ati card using up too much of your 8 usable work threads
Here I am: here I remain
Old April 17, 2010, 12:53 PM
I would personally just add the variables manually. Here is a thread with instructions on how to do it: GUIDE: ATI Client - Lower CPU % + Raise PPD - [H]ard|Forum
I suggest a FLUSH_INTERVAL of 128.
Because if he plans on folding on his CPU as well, it will make a considerable difference.
The Nvidia PhysX dilema with ATI cards chibi_man O/S's, Drivers & General Software 41 December 15, 2009 12:59 PM
Mushkin Looks to Produce ATI Graphics Cards FiXT Press Releases & Tech News 13 July 21, 2009 02:08 PM
Ati cards HaDeS HTPC Systems & Software 15 March 26, 2009 10:17 PM
New GPU core released for ATI cards LCB001 HardwareCanucks F@H Team 10 January 7, 2009 09:18 PM
XFX to sell ATI cards Jonwall Press Releases & Tech News 18 December 27, 2008 07:36 PM
