Closed Thread
  #61 (permalink)
Old May 3, 2010, 07:00 AM
LaughingCrow's Avatar
Originally Posted by chriskwarren View Post
  • Stop the FAH process (Control+C the client or stop the FAH service) or you may lose your work
I don't understand this. What is the 'client'?
I'm about 76% into my 2nd Work Unit, so I don't want to lose anything. But if I want to pause the process after it finishes 100% and before the next unit, what do I do?
I also want to stop the process so I can set up HFM.NET and then change the passkey for May 5th - will closing the Command Window stop it?
The tutorial covers everything up to getting it running, but nothing about it while it's running - i.e. pausing, stopping.
  #62 (permalink)
Old May 3, 2010, 07:57 AM
chrisk's Avatar
Folding Captain
The client is the F@H program. You stop it by pressing Ctrl-C at the same time. When you do that, the black 'console' window will disappear.
After you have done the "Ctrl-C", you need to add a command to the shortcut for F@H in order to change the username and passkey. If you don't have a shortcut yet, create one and place it on your desktop. Then, in the "Target" area of the shortcut, type "-config" . You should look similar to below: (this is an example of the config flag only...the paths of the program will look different as the image is from an older version):
After you run F@H with the config flag, and have changed the user and passkey, remove the "-config" and start normally.
Fold for team #54196
  #63 (permalink)
Old May 3, 2010, 10:31 AM
Originally Posted by Mark View Post
Thanks for your suggestions guys but I do no use a Windows login.
I said at the beginning of the guide that you need a valid Windows user account with a password in order to install the SMP client. If you don't want to set that up, then there's nothing else we can do.
Closing the command prompt window by clicking the X button at the top-right will exit the client as well.
  #64 (permalink)
Old May 3, 2010, 11:17 AM
Mark's Avatar
Thumbs up It's working...it's working!!!!!!!!!!!!
I got it to work. A few errors on my part and a clearer understanding of the system parameters helped.
Maybe a repeat and I noticed that the original sticky has been edited to encompass some of these points.
  • Setup a login Admin account with password
  • Run CMD as Admin
  • When asked for a password it is your login to your computer.
  • Carefully type in user name and team number when requested once you've created your shortcut for folding with the aforementioned renaming on your desktop ("C:\Program Files (x86)\Folding@Home Windows SMP Client V1.01\Folding@home-Win32-x86.exe" -smp -advmethods )
Thanks all for the help. Also a good noted config setup for the console client can be had here:
How do I reconfigure the console client options? - FaHWiki
So in the words of the world famous philosopher of our time...who has more midichlorians then your daily protein mix:
"It's working, it's working!!!"
Anakin Skywalker
Star Wars Episode I The Phantom Menace
Now to work on the PS3.
Cheers and thanks
CHEERS
  #65 (permalink)
Old May 3, 2010, 05:39 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
EDIT: Right now when folding it is only giving me a 25-27% load on my i5 750. How come?
  #66 (permalink)
Old May 3, 2010, 05:53 PM
LCB001's Avatar
Folding Captain
Originally Posted by SKYMTL View Post
A few questions:
- The configuration never asked for my user name and passkey yet it started folding right away. Where do I put these two items in?
- Right now when folding it is only giving me a 25-27% load on my i5 750. How come?
Possibly when the first question is answered the other will come into place. ;)
If you are using the systray client; right-click the icon and select 'configure'
If using the console client; 'CTRL-C' to close it and add either '-config' or -configonly' to your shortcut and restart.
Sounds like you are processing a uniproc. WU, make sure the -smp and/or -advmethods flags are added...
Folding For Team 54196
  #67 (permalink)
Old May 3, 2010, 05:54 PM
SKYMTL's Avatar
Both flags are added. Still the same result.
Also, getting an LE_IO_ERROR.
  #68 (permalink)
Old May 3, 2010, 05:55 PM
A few questions:
Which client are you using? Sounds like you installed the regular cpu client...
  #69 (permalink)
Old May 3, 2010, 05:58 PM
SKYMTL's Avatar
I'm using the SMP client v6.2 client which Zero linked.
  #70 (permalink)
Old May 3, 2010, 05:59 PM
chrisk's Avatar
Folding Captain
Use this guide to install HFM, and show us a screen shot with the work unit being worked on, and core folding.
http://www.hardwarecanucks.com/forum...tml#post143366
Closed Thread
Problems with SMP Client Spikemaul HardwareCanucks F@H Team 7 January 29, 2010 09:43 PM
Can't setup SMP client Lamb HardwareCanucks F@H Team 17 December 10, 2009 04:04 PM
SMP client help phil3_66666 HardwareCanucks F@H Team 17 April 24, 2009 09:34 PM
Need help setting up SMP client Alwaysrun HardwareCanucks F@H Team 7 February 8, 2009 07:47 PM
Hlpwith SMP client magictorch HardwareCanucks F@H Team 4 April 7, 2008 07:50 PM
