Closed Thread
  #51 (permalink)
Old May 1, 2010, 06:55 PM
Originally Posted by Mark View Post
Ok, the password ( I assume ) was correctly copied and pasted but now it states that "Credentials for Beaver_
Gone_Bananas rejected connecting to (my login). Press any key to continue. The password was PM'd to me.
You need to input your Windows user name, not your folding user name. The guide specifically states this, and both DenisS and myself already pointed it out to you again. The password is your user account password, not the F@H passkey.
  #52 (permalink)
Old May 2, 2010, 12:28 PM
Spikemaul's Avatar
How does one edit his username to Beavers_Gone_Bananas if he already had the SMP set up with a different name?
  #53 (permalink)
Old May 2, 2010, 12:33 PM
chrisk's Avatar
Folding Captain
  • Stop the FAH process (Control+C the client or stop the FAH service) or you may lose your work
  • Right click on your FAH shortcut
  • Select Properties
  • In the Target: field type in -config or -configonly* at the end of the line (leave a space between)
  • Click Apply
  • Click OK
  • Double Click the shortcut
  • Answer the questions
Fold for team #54196
  #54 (permalink)
Old May 2, 2010, 12:49 PM
SugarJ's Avatar
  • Select Properties
  • Click Apply
  • Click OK
And take -config flag out after changeover.
  #55 (permalink)
Old May 2, 2010, 01:01 PM
Spikemaul's Avatar
  • Select Properties
  • Click Apply
  • Click OK
I finally got it.......thanks guys.....
  #56 (permalink)
That's covered in the extra info section.
  #57 (permalink)
Old May 2, 2010, 01:05 PM
Spikemaul's Avatar
Yeah I just found it there now. I would be nice to see an official GPU Client install guide from you Zero82z because I still don't know how to change my name wiht that client.
  #58 (permalink)
Old May 2, 2010, 01:15 PM
There's really nothing to installing the GPU client. If you are using the tray client, just right-click on it, go into Configure, and change the name. If you're using the console client, then do the same thing as you would for the SMP client.
  #59 (permalink)
Old May 2, 2010, 07:45 PM
LaughingCrow's Avatar
I couldn't get it going either. (Running Win 7 64 bit) - see image "install.jpg" If I right clicked on 'install.bat' to run as administrator it didn't work.
What I noticed, my Command Window does not have "Administrator" on it but the tutorial example shows it with the prefix "Administrator"
What finally worked, was the second sentence in 4 a) from the tutorial:
"If you are using Windows 7 or Windows Vista, open the Start menu and type cmd into the search box. Once cmd.exe pops up, right-click on it and select Run as administrator. Then follow the other steps above."
Then you see the Command Window open with the "Administrator" prefix. Then use the 'cd' command to change into the directory with the batch file.
  #60 (permalink)
Old May 3, 2010, 06:55 AM
Mark's Avatar
I think you are getting the password and passkey mixed up.
You get this message I assume when you run install.bat..correct?
The password the is asked for at first is the credentials for your Windows login (that would be the password you use to log on your computer). The passkey is used after you run the fah program.
If I am incorrect or there is some confusion, could you please attach a screenshot where you are getting this error message (hit your PrtSc button on your keyboard, open Paint, paste, and crop everything out except the screen with the error messages).
I have attached where I think the issue is. In that screen you do not enter Beavers_Gone_Bananas , but your own computer login, the same one you use when you turn your computer on.
Under password, you enter your password for your computer. It is not the info that would have beens ent to you, as that is later in the guide.
Thanks for your suggestions guys but I do no use a Windows login. I pressed enter twice to coincide with a non-login account and it continues to reign in the same response of reject.
Maybe next time.
Thanks
CHEERS
Closed Thread
Problems with SMP Client Spikemaul HardwareCanucks F@H Team 7 January 29, 2010 09:43 PM
Can't setup SMP client Lamb HardwareCanucks F@H Team 17 December 10, 2009 04:04 PM
SMP client help phil3_66666 HardwareCanucks F@H Team 17 April 24, 2009 09:34 PM
Need help setting up SMP client Alwaysrun HardwareCanucks F@H Team 7 February 8, 2009 07:47 PM
Hlpwith SMP client magictorch HardwareCanucks F@H Team 4 April 7, 2008 07:50 PM
