<~----> Official Stanford Installation Guide - Page 5 - Hardware Canucks
Closed Thread
  #41 (permalink)
Old April 28, 2010, 04:38 AM
would it be possible to run the SMP client without having to put password on your computer?
  #42 (permalink)
Old April 28, 2010, 05:13 AM
AFAIK you need the password to run the smp client. The regular cpu client does not require a password but the PPD is very low compared to the smp client.
  #43 (permalink)
Old April 28, 2010, 08:36 AM
No, it is not possible. You need an account with a password to install the MPI service. There are ways to set Windows up to automatically log into passworded accounts if that's your concern.
  #44 (permalink)
Old May 1, 2010, 05:02 AM
Mark's Avatar
Question Problem
Windows 7
Running CMD as admin.
Typed in CD:\Program Files (x86)\Folding@Home Windows SMP Client V1.01>install.bat
Asks for an account : Beavers_Gone_Bananas
This is what I don't get:
Type in Password and I cannot type or paste at all!
CHEERS
  #45 (permalink)
Old May 1, 2010, 06:03 AM
Originally Posted by Mark View Post
Windows 7
Intall.bat is asking you for your windows account name (which should be there alredy, so just press enter) and password
  #46 (permalink)
Old May 1, 2010, 07:16 AM
@Mark, I had the same problem. Just type in your password, making sure there are no typos, and then press enter and retype it to verify.
I had to do the same thing, and it works just fine. :D
  #47 (permalink)
Old May 1, 2010, 10:46 AM
Windows 7
Originally Posted by Zero82z View Post
You should see a command prompt window, and it will ask for your Windows user account name.
As for the password, it does not display any characters, but it still registers your keypresses. Just type it in and press enter; you'll see after you've entered it correctly that it will work. I'll add a mention about that to the guide.
  #48 (permalink)
Old May 1, 2010, 01:46 PM
Mark's Avatar
Ok, the password ( I assume ) was correctly copied and pasted but now it states that "Credentials for Beaver_
Gone_Bananas rejected connecting to (my login). Press any key to continue. The password was PM'd to me.
CHEERS
  #49 (permalink)
Old May 1, 2010, 01:51 PM
Just double check the passkey... and the username... Beavers_Gone_Bananas (note underscores)
  #50 (permalink)
Old May 1, 2010, 02:14 PM
chrisk's Avatar
Folding Captain
I think you are getting the password and passkey mixed up.
You get this message I assume when you run install.bat..correct?
The password the is asked for at first is the credentials for your Windows login (that would be the password you use to log on your computer). The passkey is used after you run the fah program.
If I am incorrect or there is some confusion, could you please attach a screenshot where you are getting this error message (hit your PrtSc button on your keyboard, open Paint, paste, and crop everything out except the screen with the error messages).
I have attached where I think the issue is. In that screen you do not enter Beavers_Gone_Bananas , but your own computer login, the same one you use when you turn your computer on.
Under password, you enter your password for your computer. It is not the info that would have beens ent to you, as that is later in the guide.
Fold for team #54196
Closed Thread
Problems with SMP Client Spikemaul HardwareCanucks F@H Team 7 January 29, 2010 08:43 PM
Can't setup SMP client Lamb HardwareCanucks F@H Team 17 December 10, 2009 03:04 PM
SMP client help phil3_66666 HardwareCanucks F@H Team 17 April 24, 2009 09:34 PM
Need help setting up SMP client Alwaysrun HardwareCanucks F@H Team 7 February 8, 2009 06:47 PM
Hlpwith SMP client magictorch HardwareCanucks F@H Team 4 April 7, 2008 07:50 PM
