Closed Thread
  #31 (permalink)
Old April 25, 2010, 06:41 PM
Hmmm... For the a_3 core to be downloaded and installed properly, it seems you have to Run as Admin.... Or as stonee did, you can move the folder out of program files.
  #32 (permalink)
Old April 25, 2010, 07:12 PM
Originally Posted by TheWanderer View Post
Okay....
Thanks for the tip Zero. Anyway I wasn't getting any work for the DEINO client...
How do you remove an SMP client?
Uninstall DEINO>Delete the folder where you extracted ?
Thanks in advance.
Yes, uninstall through Programs and Features and delete the remaining files in the install directory.
The client does require admin privileges to run properly.
  #33 (permalink)
Old April 26, 2010, 09:37 AM
stoanee's Avatar
What would be considered normal ppd for a Q6600 @ 3.2 ghz?
heatware
  #34 (permalink)
Old April 26, 2010, 09:50 AM
Probably about 6-7k including the bonus.
  #35 (permalink)
Old April 26, 2010, 10:22 AM
stoanee's Avatar
I am well below that. 2500ppd as viewed by hfm....
heatware
  #36 (permalink)
Old April 26, 2010, 10:24 AM
Soultribunal's Avatar
I believe you have to do 10 SMP Cores folding with a Passkey in order to get the Bonus Points for early completion, with an 80% Success rate before the deadline.
ST
www.realhardwarereviews.com
  #37 (permalink)
Old April 26, 2010, 10:25 AM
Tell me what unit you're working on, and post an excerpt of your log file so I can see the time per frame.
ST
HFM has no way of knowing whether or not you qualify for the bonus. By default, it will assume that you will get the bonus regardless of your actual situation.
  #38 (permalink)
Old April 26, 2010, 10:44 AM
Dr_BenD_over's Avatar
Fallen Folder
Is there anyway I can keep my core priority and affinity? When it finsihes a WU it goes back to idle(I could have sworn I set it to high in the cfg) and all 4 cores, and never does anything with the GPU2 client running like this though, even while sucking up 75% of my CPU time. Win7 (shortly) or Vista solutions req. (64bit)
All's well that's Haswell
  #39 (permalink)
Old April 26, 2010, 12:31 PM
Polygon's Avatar
Would you guys recommend folding with this program and a quad core (q9400) or a 4870 with the advanced program? Which one is more effective?
'Do not wish for easier lives, wish to be stronger men'
  #40 (permalink)
Old April 26, 2010, 12:59 PM
To do that, you need to use a third-party application. I use Bill2's Process Manager. As for the GPU client, I have already suggested that you follow this guide to reduce your CPU usage (using a FLUSH_INTERVAL of 128): GUIDE: ATI Client - Lower CPU % + Raise PPD - [H]ard|Forum
Both. You will need to follow the link I gave earlier in this post to reduce the CPU usage of the ATI GPU client.
Closed Thread
Problems with SMP Client Spikemaul HardwareCanucks F@H Team 7 January 29, 2010 09:43 PM
Can't setup SMP client Lamb HardwareCanucks F@H Team 17 December 10, 2009 04:04 PM
SMP client help phil3_66666 HardwareCanucks F@H Team 17 April 24, 2009 09:34 PM
Need help setting up SMP client Alwaysrun HardwareCanucks F@H Team 7 February 8, 2009 07:47 PM
Hlpwith SMP client magictorch HardwareCanucks F@H Team 4 April 7, 2008 07:50 PM
