Closed Thread
Old April 24, 2010, 09:50 AM
Originally Posted by stoanee View Post
Damned if I know how to do that............
I've added instructions on opening a command prompt with Administrator privileges to the guide under 4a.
Old April 24, 2010, 04:35 PM
Thanks Zero! Much better than the one on the Official page.
Old April 24, 2010, 08:47 PM
Any chance of a DeinoMPI guide?
Thanks in advance. :D
Old April 24, 2010, 09:39 PM
No. Use MPICH instead. DEINO is unsupported and is also incompatible with 64-bit versions of Windows.
Old April 24, 2010, 10:11 PM
stoanee's Avatar
"Open SCManager failed, Access is denied. failed to remove previous installation. Install failed. account (domain\user) [q6600\user]:"
When I right click on install bat and try run as administrator nothing happens. A screen flashes by and disappears. When I try to click on it again this is what I get.
heatware
Old April 24, 2010, 10:17 PM
Read 4a.
Old April 24, 2010, 10:29 PM
stoanee's Avatar
Originally Posted by Zero82z View Post
Read 4a.
Doh...
Well now I get Unable to connect to Q6600 bla bla bla
sock error:generic socket failure. error stack
MPIDU_Sock_post_connect(1228): unable to connect to Q6600-PC on port 8676. exhausted all endpoints (errno -1)
MPIDU_Sock_post_connect(1228): unable to connect to Q6600-PC on port 8676. An attempt was made to access a socket in a way forbidden by its access permissions (errno 10013)
press any key to continue...
It was never this difficult before............
heatware
Old April 24, 2010, 10:41 PM
geokilla's Avatar
Reinstall and try again?
From my knowledge, port is usually associated with networking, so maybe Windows Firewall or some other firewall is blocking folding@home?
  #19 (permalink)
Old April 24, 2010, 10:46 PM
If you are using Windows Firewall, you should see a popup asking you if you want to make an exception for F@H. If you don't see it or accidentally clicked no, try turning off Windows Firewall altogether and see if the install process works. If you are behind a router, Windows Firewall is pretty much useless anyway.
  #20 (permalink)
Old April 24, 2010, 10:47 PM
stoanee's Avatar
Done and done, no change.
heatware
Closed Thread
Problems with SMP Client Spikemaul HardwareCanucks F@H Team 7 January 29, 2010 08:43 PM
Can't setup SMP client Lamb HardwareCanucks F@H Team 17 December 10, 2009 03:04 PM
SMP client help phil3_66666 HardwareCanucks F@H Team 17 April 24, 2009 09:34 PM
Need help setting up SMP client Alwaysrun HardwareCanucks F@H Team 7 February 8, 2009 06:47 PM
Hlpwith SMP client magictorch HardwareCanucks F@H Team 4 April 7, 2008 07:50 PM
