  #21 (permalink)
Old January 7, 2008, 04:54 PM
sswilson's Avatar
Yeah, I'd have to run two instances of the Linux SMP client under Ubuntu to make full use of the memory.
I might even run the standard client alongside the SMP client (assuming it would work) to use up the extra cpu cycles.
As it stands.... the SMP client under Ubuntu doesn't even use 400 meg ram :)
  #22 (permalink)
Old January 7, 2008, 04:56 PM
3.0charlie's Avatar
Just like under Windows; only way out, in order to fully use the Quad.
Hydro-Quebec is salivating...
  #23 (permalink)
Old January 7, 2008, 05:13 PM
How much ram do you guys allocate to each VMWare instance? With 2gb ram, my system bogs down when I use other programs with VMWare (with Ubuntu64 7.10) X 2 using 500mb each. It's probably time to shell out for 2 x 2gb modules (my maximus acts funny with 4 modules).
Q6600 G0 @3.5ghz (Thermalright Ultra X 120)
Asus Maximus Formula 903
A-Data DDR 800 4 x 1gb, EVGA 8800GT SSC (Zalman VF900)
Antec NeoPower Blue 650W, Antec 900
HTPC: X2 64 5000+ Black @3.3ghz (AC 64 Pro)
A-Data DDR 800 2 x 1gb, Radeon 2600 Pro HDMI
Asus M2N-E, Antec Sonata, 380W TruePower
  #24 (permalink)
Old January 7, 2008, 07:35 PM
3.0charlie's Avatar
Your system bogs down because of the 96%+ CPU utilization, not the ram usage.
Using 2Gb, I allocate 900Mb to each instance. If I wish to use other programs, I stop both FAHs using the CTRL+C function, but leave VMware and both Ubuntu instances operating. That allows me to have any software up-and-running smoothly, even 3D design software.
And the Windows I'm using is Vista Ultimate... so if you wish to go for 4Gb, you'll be more than pleased; working with Windows with 2Gb is very much feasible too. If you stop the FAH instances, either way.
  #25 (permalink)
Old January 28, 2008, 07:33 AM
sswilson's Avatar
M y native Ubuntu folding folding experiment is going to wind down over the next couple of weeks. The PPD just isn't comparable to what I'd see using two VMware instances under XP.
I'm seeing slightly over 4000 for the 3060 quad core beast, and only slightly over 3000 for the other common quad core WU 3062. 2605 & 2653 both come in at around 4100 PPD.
I'm pretty sure I'll see a lot better than that running two VMware instances under XP (I'm hoping to see around 6K with this chip running @ 3.8 24/7) so I'm going to go that route when I re-install everything once my new vid card comes in.
Did you do a write-up on how to set up the two VMware instances Charlie or am I going to have to do some digging? :)
  #26 (permalink)
Old January 28, 2008, 09:03 AM
3.0charlie's Avatar
I've dug it out - http://www.hardwarecanucks.com/forum...ta-vmware.html. I would read the entire thread, since that was written at the same time that Stanford was updating the Client. I've been using this method for both Quads (3.6GHz) and it produces 4700 ppd day-in, day-out.
It's odd to see pscout's old replies. I miss him.
Folding @ Home F.A.Q. Supergrover HardwareCanucks F@H Team 229 May 15, 2010 08:24 PM
E8400 + Folding = OMG... 3.0charlie HardwareCanucks F@H Team 40 March 2, 2009 08:23 AM
Newbie GPU Folding Shredder HardwareCanucks F@H Team 11 February 24, 2008 10:55 PM
Whoa... what happened? 3.0charlie Suggestions & Feedback 36 February 22, 2008 10:52 AM
Two folding machines Amon HardwareCanucks F@H Team 16 September 14, 2007 04:05 AM
