Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > HardwareCanucks [email protected] Team
  #21 (permalink)
Old April 16, 2010, 06:26 PM
xeon 3440. ht on, clocks nice. whats wrong with 6 gigs on 1156? :) som e say you can still run dual chan or hwatever
  #22 (permalink)
Old April 16, 2010, 07:44 PM
3x2GB cannot be used in dual-channel mode. One of the sticks will be left in single-channel mode, which is not an ideal configuration. -bigadv units also benefit quite a bit from RAM performance, and having one stick in single-channel mode could have a noticeable negative impact on [email protected] performance.
  #23 (permalink)
Old April 16, 2010, 08:12 PM
2x2GB + 2x1GB can be the same or cheaper than 3x2GB and you can save $50 on the CPU and $60 on the board. I have an x3440 with 8GB of ram and it seams to run bigadv's fine while I browse the web though it often uses 6.5GB of ram total with chrome and windows 7. I have even been playing HL2 while folding. I'm drawing 215W with [email protected], an inefficient power supply and an HD 4830 idle.
Still ends up expensive though.
First water setup for MM88 martin_metal_88 Water Cooling 93 June 15, 2010 05:32 PM
Let's give this another try.. Dr_BenD_over HardwareCanucks [email protected] Team 3 February 24, 2010 06:30 AM
To give a gift Caldezar Off Topic 2 December 19, 2009 04:24 PM
Crazy GPU PPD, Crap CPU PPD, help please Taz HardwareCanucks [email protected] Team 5 July 31, 2009 05:37 PM
So, any last ideas before I just give up? donimo Overclocking, Tweaking and Benchmarking 34 February 26, 2009 10:54 AM
