Ever wonder how much power F@H actually. Well here are my results.
The system that I tested on is the following:
i7 920 @ 4.5GHz, 1.3375Vcore, 1.2Vtt
9GB DDR3 @ 643MHz, 8-8-8-24, 1.56Vdimm
X58 E760 Classified
8800GTS 640MB @ 621/1455/900
30GB Vertex
1000W Antec Quattro. Which is around 85% efficiency on the loads I am testing.
I used the
Blue Planet Energy Meter to find the wattage that is being pulled from the wall. I am using Calgary power rates for these results. Which at the time of posting is 5.951 cents per kWh. I have disabled Speedstep & C1E.
Now for the results.
Watts shown is what is the whole system power consumption taken from the wall. $ amounts are per month.
IDLE-> 265W =
$11.35
Running 8 thread -bigadv -> 430w =
$18.42
8800GTS ONLY. P5785. 783point -> 321W =
$13.76
8800GTS P5785 & bigadv -> 488W =
$20.91
If you are the kind of person who leaves your machines on 24/7 to either download or whatever,
it is only going to cost an extra $7/month to run a bigadv client. And if you leave the client on idle priority it really
doesn't interfere w/ gaming.
If anyone else has a power meter I would love to see what your system power consumption is for videocards.
